Progress Springs....?
Old Jul 5, 2003
DaZeD's Avatar
Don't Hate. Just Envy.
So Im looking to purchase progress springs for my 2k1 coupe. Im riding on 17in Konig Verdicts with Kuhmo Supra Ecsta tires, 215/45. I was wondering what all of you think about progress springs and if i should be encountering any probles, like i would need to get a chamber kit. Oh and the drop is (f)1.75 and (r)2.00
Old Jul 5, 2003
robbclark1's Avatar
Retired suspension supermod.
It is a really low drop. My friend had them and liked them but because it is a low drop you will need a camber kit and your stock shocks will blow quite quickly. Progress makes good stuff!!
Old Jul 5, 2003
iceman's Avatar
--< GripSpeed Member >--
hey wassup...i have progress springs wit 215/45/17s...my shocks are fine...but for sure u will need a camber kit..and u will also have to roll ur fender or they will rub...at first they wont..but once the springs settle they will rub
Old Jul 5, 2003
reytito's Avatar
yes it won;t be 1.75/2.00 for long. it'll be more like 2.0/2.25. which is nice i think. i lovemy progress...its not too noisey..not as bad as the prokit. ride is pretty comfy. go for it.
hey ICEMAN: do you think my 16's with 105/45/16 will rub? also if i gotta get a fender job, how much you think i'm lookin at? thanks.
Old Jul 6, 2003
iceman's Avatar
the tires...i am not sure...u just might be able to clear it...just depends how much lower ur springs settled...as for rollin ur fender...it should be that expensive...i had a shop in cali...do a 4 wheel alignment, correct the camber, and roll the fender for bout 120...ive heard people say that u can roll the fender urself wit a bad wrapped wit cloth...but i didnt want to take the risk of crackin the paint
Old Jul 6, 2003
DaZeD's Avatar
hey iceman, where in la is the shop maybe after i install the springs at tech day i can go
Old Jul 6, 2003
iceman's Avatar
its actually on montery pass...its called grand prix...just ask them how much sepeartly..then talk them into givin u a cheaper price if u do it all at the same time
Old Jul 6, 2003
iceman's Avatar
oooooh..forgot..dont do it right after u install ur springs..wait a couple days so that they can settle..also if u wanna see how low ur car will be..when u have 215/45/17s on progress sprigns..u can check out my ride..when i show up at the meet
Old Jul 6, 2003
iceman's Avatar
heres a pic of my car wit progress springs before they settled
Old Jul 6, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
Well, I have them, and now since my back shocks have blown, I hate the ride. Ok, progress uses progressive spring technology. The spring if you look at it is more coiled in the bottom and less on top. That is supposed to give a softer ride. The problem is, that our shocks blow. The 2k1 civic has different suspension on it from 2k2 and 2k3. As well, some 2k1's have the redesigned suspension, but there is no date on when the change over happened. Either the drop will be even, or if you have the old stuff, the drop will be like almost 3" in the back and 2" in front. Make sure you get shocks in the end. I have had mine on for 2 months with almost perfect rodes and the shocks have blown in the back. Try them if you like, I personally would go with goldlines now. But these have lowest drop
Old Jul 6, 2003
DaZeD's Avatar
my only problem with getting them would be that:
a)its too low and ill **** up my ride on the streets of La
b)after i pay 115 for them(used by the way) then i would need to get a chamber and even then possibly new shocks. Im not sure how much a chamber kit would cost but i think its around $200 and also maybe have to get my tires tucked
c)what the ride would be like, like how smooth would it be, especially living where the roads are somewhat bumpy and there are a SHITLOAD and I mean a SHITLOAD of speed bumps
can any of you relate to any of those problems or what do u have to say now
Old Jul 6, 2003
iceman's Avatar
hey wassup...right now ive had my sprigns for bout half a year...and my shocks havent blown..and i drive my car pretty darn hard...as far as too low...once in awhile ull get driveways..that are too low..but other than that your fine...however if u add a kit..ur screwed...for me imma get coils now..cuz i plan on gettin a kit...and its pretty much goin to have the slammed look if i keep the progress on...as far as the ride...i love it..its nice and smooth...but wit rims...and low pro tires..it wont be as smooth like stock when u had those really really thick tires
Old Jul 6, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
i have the springs and the same tire size. the rear has negative camber. my prediction is that if u correct the rear camber had have a tire sive of 215 it WILL RUBB. this is also confirmed from what ICEMAN said. so i have the SPC camber kit and its uniinstalled. the drop is pretty low. the first time u sit in your car you will notice it. handling is alot better too.
these springs are STIFF as hell. u will feel every single bump! i have hit some heavy potholes and my shocks are still ok, but they wont be if i continue to hit these 1.5+ inch deep potholes were have in philly. pictures attached
Old Jul 6, 2003
2k1civic.com O. G.
pic2
Old Jul 6, 2003
2k1civic.com O. G.
pic3
Old Jul 6, 2003
2k1civic.com O. G.
its actually a bit lower now. those pics were taken the day after memorial day. so it has settled by now. here is a before pic
Old Jul 6, 2003
DaZeD's Avatar
i decided that i want to upgrade to 18s now, so thanx for all the help bu i think im gonna put the 18s on first then go with springs with a smaller drop, possible nuespeed sports maybe goldlines, i just think that here in La 18s and a 2in drop will be beneficial
so i guess a mod can close this topic, but once again thanx for all the help
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
NROD315
Jul 21, 2015 07:46 PM
badcivic2002
15
Jun 30, 2002 08:59 PM
importable
Mar 4, 2002 09:12 PM
