Differncce between tuner lugs and regular lugs?
Old May 20, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Hey guys, I just purchased a set of rims that I will be putting on my car on friday and was wondering if I could use my factory lug nuts? I know some people have tuner lug nuts which are much longer. I have velox vx8's, I've heard it's tougher for a thief to take the tuner lugs off, is it true. I also have to get a set of lock nuts, thanks
Old May 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You can't use the stock ball ended lug nuts.. they won't seat properly on the wheel. Tuner lugs typically have an internal hex pattern rather than an external one (looks like an allen bolt rather than a Hex nut) so they slip into the tiny hole the manufacturer left in the wheel to get a lug nut through. I don't know if tuner lugs are harder to get off, they'll come off like any other nut, as long as you have a set of decient locks you should be covered... a determined thief will get them if they want, but its enough to deter the idiots.
Old May 20, 2003
AllMotorSi's Avatar
thanks,
Old May 21, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Get TWO sets of locking lugs for extra security.
Old May 21, 2003
Travii's Avatar
Travii is an unknown quantity at this point
Tuner lugs are for small diameter holes in wheels. They have a "key" but its the same as every other "key" that a tire shop gives out for tuner lugs. If you really don't want to get jacked take slammedblueem2's advice and get two different sets of WHEEL LOCKS not tuner bolts.
nirvanaguy
25
Oct 26, 2017 07:26 PM
AffliictiioN
Sep 16, 2015 02:21 PM
siliconvalley
Sep 15, 2015 09:48 PM
Dsmak
Sep 10, 2015 08:30 PM
