Just put rims on
Old Apr 28, 2003
girliegirlcivic's Avatar
girliegirlcivic is an unknown quantity at this point
Question Just put rims on
My b/f just put rims on my car and when the car gets 50 mph and higher my steering wheel shakes, do I need to get the wheels balanced and aligned? Or could it be something else?
Old Apr 28, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Re: Just put rims on
Originally posted by girliegirlcivic
My b/f just put rims on my car and when the car gets 50 mph and higher my steering wheel shakes, do I need to get the wheels balanced and aligned? Or could it be something else?[SIZE=1][SIZE=3][FONT=times new roman][COLOR=red]
Yes. Balanced and aligned would be a good thing. And IBTM.
Old Apr 28, 2003
Spazbitte's Avatar
Spazbitte is an unknown quantity at this point
Yeah and hopefully he knew what he was doing and torqued them down and in the right order. Rims should have already been balanced when they were mounted you just need an alignment.
Old Apr 28, 2003
Drnknmnky13's Avatar
Here's something I learned the hard way. It might not be the cause of your imbalance...but figured I would share anyway. My car had a bad shake in the front tires. It was really really bad on cold days. Turns out there was water in my tire. I usually fill my tires up at the gas station near my house. It seems that condensation builds up inside the line and it gets pushed into the tires when filling them. I now spray air out of the tube before putting it in my car. You'd be amazed at what comes out of the nozzle with the first spray. Ohhh the reason the tires were really bad on cold days? The freaking water froze!!! Just a little heads up.
Old Apr 28, 2003
666's Avatar
666
666 is an unknown quantity at this point
By any chance did he install hub centric rings like you are supposed to?
Old Apr 28, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
i gotta question i get new rims all the time and install myself and yes i torque them down in the right order but do i need reallignment every time i get new rims. car drives perfectly straight and no shakes until about 90-95 when i feel slight shaking but nothing bad at all.
riley
Old Apr 28, 2003
666's Avatar
666
No you don't need an alignment every time you get tires, you can have them check the alignment to see if possibly it has changed at all, but it should not need one if your tires wore even across the entire tread. After altering any suspension component (springs, shocks etc...) then you will want to get one to be sure everything is even on all four corners and a maximum tire to road contact patch is met for saftey and for your tires.
Old Apr 29, 2003
fastlx's Avatar
fastlx is an unknown quantity at this point
Alignment will not cause a shake. It is one of many things, most have been covered. It could be something in the tire. They could need hub centric (centering) rings. They might not be torqued properly (should be done after the first 25-50 miles of putting on new wheels). Or what it probably is, the balance is off. Take it to a tire shop, tell them the problem and I would be that they need to be rebalanced. As for alignments, if you are just replacing existing tires (stock) then if they wore properly the alignment does not need to be checked. If you are installing after market wheels/tires (different size from stock) you should have the alignment checked due to the wheel sitting different on the vehicle (offset). Hope this information helps.
Chris
jbander
Wheels and Tires
Jul 10, 2015 05:26 PM
Shabba
Jun 12, 2015 05:50 PM
HomelessSanta
May 14, 2015 09:53 PM
Pudnite
May 9, 2015 07:51 PM
