Tire rub, lowering, camber etc.
Old Apr 4, 2003
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
On my 2k1, I had my 17" tantrums with 205/40/17s, lowered with goldline springs about 1.75". I didn't ever fix the camber, but it looked like if the rear wheel's camber was fixed that the top of the tire would rub the lip on the fender well. ... . . Well, now im fixin to drop my 2k3, put the same rims and tires on, but im putting camber kits on as well, should I anticipate a problem with rubbing? has anybody else run into this problem?
Old Apr 4, 2003
dragoon's Avatar
not with 205/40s you're not
Old Apr 4, 2003
666's Avatar
666
666 is an unknown quantity at this point
As long as you have your camber adjusted properly so they tuck in behind the fender it should not be a problem, if it will be that low. Like dragoon said with 205/40's they should'nt rub at all.
Old Apr 4, 2003
Ha0sVtecEX's Avatar
Ha0sVtecEX is an unknown quantity at this point
yep probably your camber is not adjusted ,i got 2k1 civic with 17's and 204/40 plus the goldlines and i don't hear a sound,,
Old Apr 4, 2003
synikal's Avatar
synikal is an unknown quantity at this point
I have a coupe with goldlines, 205/40/17's, and camber kit front and back aligned and I dont rub at all.....in fact I have a little gap that I might try to fill up by buying some 205/45's or 215/ 40's.....but I dont think you will rub at all.
Old Apr 5, 2003
DizWikedCivic's Avatar
205/40/17 will not rubb with a 1.75 drop, i have a 2.75 drop in the front and no rubbing, but the rear might rub depond the camber
Old Apr 5, 2003
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
I've got 18's with 225/40/18 rubber and Goldline drop.. absolutely no rubbing at all! I have been driving pretty wildly too in the past couple of days and no rubbing.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
They shouldn't rub.
Pudnite
May 9, 2015 07:51 PM
bo_red
Apr 23, 2015 10:09 PM
NightKids2
Dec 8, 2001 05:50 AM
technosilver
Nov 14, 2001 10:58 AM
EvilTwin
Nov 8, 2001 12:17 PM
