wheel alignment
Old Mar 30, 2003
NBPD17A2's Avatar
NBPD17A2 is an unknown quantity at this point
wheel alignment
I plan on putting on 15" x 6.5" wheels and 205/60-15 tires and was wondering how badly this will mess up the alignment, if at all? From what I understand, once you lower the car is when things start going out of alignment and that you dont necessarily need a camber kit if you find a shop that is willing to align a lowered car. Do our cars have the flexibility to adjust to being lowered or is the camber kit necessary?Has anyone figured out the alignment specs for a lowered 7gen Civic?
thanks.
Old Mar 30, 2003
flotsamm's Avatar
Just putting on different tires and wheels wont affect the alignment. However, lowering your car can, depending on the amount of drop. Some peeps say that if you only drop it a little like an inch that you wont need a camber kit or alingment done. Best to follow what the spring manufacture recommends about lowering. Also our cars dont come with any allowable camber adjustments. You must buy and install some sort of camber kit.
Old Mar 31, 2003
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
If your lowering your car more than an 1" all around, I'd recommend a camber kit.
Old Mar 31, 2003
Cisco88's Avatar
Cisco88 is an unknown quantity at this point
I dropped my car with H&R sports, and people said before that you didn't need to have a camber kit........
But I do.....plus I hit a few potholes this winter....
Old Mar 31, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Re: wheel alignment
thanks.
It is said that if you put bigger wheels on, you should get an alignment.
Get an alignment after you are completely done with modifying your suspension.
The front will align correctly by itself. For the rear, you should get a camber kit.
And don't alignment specs vary from cars? It should depend on how low that car is, correct? Not every car is at the same height especially after being modified.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
After I put my rims on I needed an alignment. But my car had never had an alignment so that could be why Alignment checks are usually free, so to be on the safe side I'd get it checked. If your alignment is out you'll get uneven treadwear on those new tires you're buying.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
BryanM.
Aug 29, 2015 03:26 PM
jedi
Aug 3, 2015 04:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
