Ghetto Camber kit?
Old Dec 20, 2002
hondah1's Avatar
hondah1 is an unknown quantity at this point
Ghetto Camber kit?
whats up - one of my friends told me he can save me some cash buy buying parts from home depot and make me a camber kit...he did it on his Integra - but the thing is, aren't the set-ups on our cars and the tegs different? If not, should I try this? He knows quite a bit about
cars, his ride is tight as hell, and lowered 2.5 inches all around. Whut ya think? I don't think i will be getting a camber kit for a while, so this seems like a good alternative...also - should I get an alignment if i am not getting a camber kit anytime soon (maybe a few months away)
damn! is this the right forum for this I hope???? my bad if no!!
Old Dec 20, 2002
mohawkboom's Avatar
it's the right forum...no it won't really work...and if it did..it wouldn't be strong enough
Old Dec 20, 2002
Edens's Avatar
Edens is an unknown quantity at this point
How can you say it wont be strong enough if you dont know what he is going to make it out of?[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Dec 20, 2002
DizWikedCivic's Avatar
integra and our car have different suspension, has for te integra the rear camber kit is just a bolt a washer but integra need front camber kit, but out car are mcpherson susupensino so we need a camber arm but we dont need front camber kit
Old Dec 20, 2002
VNlilMAN's Avatar
The Standard One
ya the suspension on the cars are different... you can use bolt+washers for the integ/older civics cause of how its mounted. its mounted from the side, but our cars are mounted from the bottom up... so ya theres people that say it wont work BUT... i think theres a slight change it might. cause you add 10 washers and a really long bolt.. the camber is not going to stay the same, its going to change. your obviously not going to use 10 washers but i'm just using it as an example since it easier to picture. i would say try it, if it doesnt work, oh well you lost $5 and 30 mins of your time. i've been meaning to try it for the longest time now but i've been lazy. ya and i dont see why it wouldnt be strong enough... i think it should work..
Old Dec 22, 2002
chirpin2k2civic's Avatar
chirpin2k2civic is an unknown quantity at this point
Quote
[hr]Originally posted by: VNlilMAN
ya the suspension on the cars are different... you can use bolt+washers for the integ/older civics cause of how its mounted. its mounted from the side, but our cars are mounted from the bottom up... so ya theres people that say it wont work BUT... i think theres a slight change it might. cause you add 10 washers and a really long bolt.. the camber is not going to stay the same, its going to change. your obviously not going to use 10 washers but i'm just using it as an example since it easier to picture. i would say try it, if it doesnt work, oh well you lost $5 and 30 mins of your time. i've been meaning to try it for the longest time now but i've been lazy. ya and i dont see why it wouldnt be strong enough... i think it should work..[hr]
what he just said =)
Old Dec 22, 2002
dont even waste your money on it, just buy a camber kit
Old Dec 23, 2002
VNlilMAN's Avatar
The Standard One
well its only like $5 the most... what if it does work, you save $120. if it doesnt, oh well you have extra washers in your tool box..
Old Dec 23, 2002
hondah1's Avatar
Cool - gonna try it, good weekend project. And like a couple of ya said - it's not like it will be any loss if it doesn't work - and I'll let you know when I try it
Old Dec 23, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Why this will not even work.
If you picture your rear suspension, it is a trapezoid with unequal arms. When you lower the car, you are moving one side of the suspension higher, this causes the tire to turn in, thus causing negative camber.
To correct this, a new camber kit, or adjustable top arm uses a turnbuckle to expand the distance between the top two angles. This causes the top of the tire to go out, thus restoring the camber.
This is why the older Civics could use this method. The top arm was mounted to the side of the frame. So adding washers increased the overall length of the arm and added some positive camber.
The 7th generation Civic uses a mounting method that places the bolts down. If you add washers to the mountiong point, you are in effect lowering the inside top mounting location and decreasing the amount of camber (or making your car have even more negative camber). So instead of helping, you are making matters worse.
To top this off, you will need METRIC bolts to even try this, and they would have to be grade 8 or higher to avoid sheering the bolts off and your wheel falling inside your wheel well. You will not just find these bolts, it will be a bit harder than that. Plus if you do the math, basic Geometry, you will find that it will hurt you not help you.
Plus when you do have a camber kit, the shop uses an expensive machine to accurately measure the wheel position, then adjusts the turnbuckle to add positive camber.
Basically, this will be a waste of your time to do this. Save up for a camber kit or buy tires more often, that is your only two choices.
Old Dec 24, 2002
VNlilMAN's Avatar
The Standard One
well ya thats what i was saying.. if you add washers its not going to be the same(the camber).. its either going to give you a positive or negative.. but then i guess it'll give you negative as rick said so it wouldnt help...
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
