Tire Size/New Rims question
Old Nov 18, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
If I decide to get new 15" rims such as these, can I use my stock sized tires (notice I said stock sized not stock) on them?
Old Nov 18, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Should be able too but stock tires suck if they are firestones
Nick
Old Nov 18, 2002
nbpEMCivic's Avatar
Notice I said stock sized, not stock...but thanks for your answer.
Old Nov 19, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
How wide are the rims? 185 is a pretty skinny tire if the rim gets wider than the stock 6". 195/60 or 205/60 will keep you pretty close to stock size, and give you a wider tire if the rim is wider than stock, but you should be able to get by with the stock size if you want also.
Old Nov 19, 2002
nbpEMCivic's Avatar
The reasoning behind me wanting to get away with stock size is money of coruse. So I guess I need to find out if anybody knows the width of the Rota SubZeros (15 inch).
Old Nov 21, 2002
nme3's Avatar
JDM wannabe
switching stock to 15" rims wont call for a balance will it?
Old Nov 21, 2002
Jap-Euro Fusion
Quote
[hr]Originally posted by: nme3
switching stock to 15" rims wont call for a balance will it?[hr]
Any time the tire is removed from the rim, you need to have it re balanced. Regardless of the size of the rim. Even when you have tires changed on the same rim, it isn't going to be the same. So yes, you need to have the new rims balanced, even if you transfer the tires.
Shabba
Jun 12, 2015 05:50 PM
Pudnite
May 9, 2015 07:51 PM
bo_red
Apr 23, 2015 10:09 PM
technosilver
Nov 14, 2001 10:58 AM
