Squeaking Brakes......
Old Nov 16, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, I have had a problem with my right front brake. It is always sqeaking and I can't get rid of it. Is there something that I can just spary inbetween the disc and the brake pad that will get rid of the noise or do I have to remove the whole brake to clean the break pad?
Old Nov 16, 2002
Roadog's Avatar
Roadog is an unknown quantity at this point
Are your brakes worn down to the metal tab that makes a squeaking noise to let you know that they are worn out? Are they aftermarket pads?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 16, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
mine are starting to sqeek as well.....car has 36k miles on it...i think its almost time for new pads..
but i dont want to buy new pads, i want to just buy the aem big brake kit
Old Nov 16, 2002
player's Avatar
yeah man in the civic hand book, it says that if your break start to sqeak then they are worn out to the metal.
Old Nov 16, 2002
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
Mine sqeaks occasionally, usually when I'm braking while turning at low speeds. I only got 3200 miles. It's starting to worry me. It doesn't happen often, but it happens...
Old Nov 16, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
Usually 2 reasons. Sand between the pad and rotor or indicator telling you it's time for new rotors. If you only have 3200 or so miles, probably got crap on the pads. They're easy to change if it bugs you enough.
Old Nov 17, 2002
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
i have already gone through this thing, its quit simple our brakes suck a$$. i had like 12k on mine and the front right brake was basically all the way gone i had about a mm left of brake. another reason you might hear the squeaking is the bolt that holds the calliper down might be on to tight or loss which will cause the brake to wear unevenly which in the end will make your brakes squeak cause one end of the bad is gone. just go buy the aem brake pads which serve more than one perpose. they are awsome since there is no visible brake dust a real up side if you have rims. also they work a lot better i think than the stock ones, and they are easy to install [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 17, 2002
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
Quote
[hr]Originally posted by: IllusiveImports
i have already gone through this thing, its quit simple our brakes suck a$$. i had like 12k on mine and the front right brake was basically all the way gone i had about a mm left of brake. another reason you might hear the squeaking is the bolt that holds the calliper down might be on to tight or loss which will cause the brake to wear unevenly which in the end will make your brakes squeak cause one end of the bad is gone. just go buy the aem brake pads which serve more than one perpose. they are awsome since there is no visible brake dust a real up side if you have rims. also they work a lot better i think than the stock ones, and they are easy to install [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
AEM brake pads, are they just as efficient if not better than regular pads.
Old Nov 20, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
about the breaks. i ordered the ones for the 2001-2002 civic off the website, but on the box they sent, it says 96-98 civic. the part # is the same on the website as on the box. u guys think they will fit or no?
ghondavic
Transmission
Apr 12, 2017 09:37 PM
czarlun
Sep 14, 2015 08:16 PM
cukaracha
Aug 29, 2015 05:27 PM
sovereign82
20
Jan 10, 2004 05:31 PM
01CivicEXs
Brakes
Apr 17, 2002 08:10 PM
