drilled and slotted roters
Old Nov 5, 2002
Willy's Avatar
Willy is an unknown quantity at this point
where can i buy drilled or slotted rotters to fit my car.
Old Nov 5, 2002
sspem2's Avatar
em2
whats the difference between drilled and slotted rotors? i asked this question like 5 times now and i never get an answer. is there an advantage to slotted or drilled or what?
Old Nov 5, 2002
VNlilMAN's Avatar
The Standard One
drilled and slotted rotors cool down the brakes faster. this improves braking
Old Nov 5, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
[hr]Originally posted by: 1siksivik
whats the difference between drilled and slotted rotors? i asked this question like 5 times now and i never get an answer. is there an advantage to slotted or drilled or what?[hr]
Crossdrilling helps to cool the brakes down.
Slotting helps to prevent pad glasing and helps outgassing under hard braking.
The disadvantage to Drilling them is they are very prone to cracking.
Old Nov 6, 2002
ripper's Avatar
ripper is an unknown quantity at this point
In response to this, true or not I do not know for sure, I would not buy drilled or slotted rotors. I was told by a friend (who races professionally) that the reason they drilled rotors originally was to reduce weight. In race cars there are gigantic rims that accomodate massive brakes. The reason they were drilled was to reduce weight. From other friends I have had, they were very unhappy with the results of these rotors on the street, because they tend to chew up brake pads at an expedited rate. Just some food for thought....anyone else know more on this subject?
Old Nov 6, 2002
YS's Avatar
YS
YS is an unknown quantity at this point
it's cool down the brake and also , it's look GOOD
Old Nov 6, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
like previously noted, both metods are used to cool the rotors down, as for saving weight, i havent heard anything about this.
ive also heard that the cross-drilled are more prone to breaking, but i havent heard anything like that about the slotted.
and IMO, when it comes to your cars performance, you shouldnt buy something JUST because it looks cool.
Old Nov 7, 2002
Zzyzx's Avatar
Autocross Junky
Boilermaker1 had it right. Drilled = Cooling of the roter (Roters mfged now can withstand much higher temps.) Slotted = reduce risk of brake fade (Pads mfged today dont brakedown as quickly so they dont "fade" as much). However with the modern meterials used in brakes today you will never find it nessisary to have either on a mid to light weight car on the street. If you race a lot you may incounter brake fade (I'm taking about racing as in on the track not drag.) The best way you can improve brake performance on our cars is to get steel braded brake lines and up grade the pads to a more performance pad. other wise your just buying roters for that "look".
My policy for my car is "If it dosn't make it go faster or handle better is isn't going on my car".
Old Nov 7, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
I brake hard a lot, and my rotors tend to warp rather frequently. Right now I have 15,800 miles on my 7th gen and I need to get the rotors resurfaced.
After the original set of rotors on my 6th gen warped for the first time, I replaced them with some Brembo cross-drilled rotors, and they never warped again. I also put some performance brake pads on, and between the two, my braking performance was increased noticeably.
So to get back on track with the original question: Where can we get slotted or drilled rotors for our 7th gens? I've look all over the 'net and all I can find is for 6th gen and older.
Old Nov 7, 2002
ripper's Avatar
I believe ptuning has them
Old Nov 7, 2002
YS's Avatar
YS
JMO USA
they have the brembo.
Old Nov 7, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
coximport.com
brembo makes them for our cars.
u can find them on ebay too.
Old Nov 8, 2002
part of the reason stock rotors warp and aftermarket(basic or drilled/slotted) usually dont is because stock ones are steel which has a lower "melting" point than aftermarket aluminum ones. all drilled/slotted, to my knowledge, are aluminum.
Old Nov 8, 2002
WD40's Avatar
Quote
[hr]Originally posted by: EternalVTEC
part of the reason stock rotors warp and aftermarket(basic or drilled/slotted) usually dont is because stock ones are steel which has a lower "melting" point than aftermarket aluminum ones. all drilled/slotted, to my knowledge, are aluminum.[hr]
Hmm, that's an interesting point. I hadn't thought of that before.
Old Nov 8, 2002
FiremanJoe's Avatar
FiremanJoe is an unknown quantity at this point
Try www.tirerack.com, they have brembo, powerslot, and ebc rotors and pads, as well as hawk pads too. Thats where i got my ebc rotors and pads and there is a noticeable difference in braking compared to stock, especially in high speed brakeing.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 8, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
iRotors.com have them for our cars for like $100 bucks. i think.
Old Nov 23, 2002
vino's Avatar
vino is an unknown quantity at this point
are the rotors on i rotors.com brembo?
Old Nov 26, 2002
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
According to this drillled rotors are actually for less weight and it does not cool as well. Willwood faq
danace99
Oct 17, 2015 02:51 PM
amrhamed
Sep 21, 2015 02:56 PM
nixyfior
Sep 14, 2015 08:32 PM
Gsxtacy
Sep 12, 2015 01:09 AM
Pier7866
Sep 6, 2015 06:54 PM
