should i get a camber kit???help!!
Old Jul 21, 2002
dezod's Avatar
7thgen Power Maker
guys, i need your expertise.....i just an eibach pro kit and haven't put it on yet....it's a 1.3" back and 1.1" front....i have enkei 17" 215/45/17z's......will i need a camber adjustment kit? i also need to know if a $100 for an ingalls kit is good. help!
my bitch!
Old Jul 21, 2002
mohawkboom's Avatar
the Ingalls kit is $100 per side if I recall correctly..also with that drop you might not need any camber adjustment..
Old Jul 22, 2002
TOOLOWCIVIC's Avatar
You shouldn't need one. But it wouldn't hurt if you got one.
Old Jul 22, 2002
Mbow's Avatar
I used to have the prokit springs on my car. The rear was sitting at -2.5 degrees but the front was ok. So, yes, I needed the camber kits for the rear. I decided to drop the car more with a set of neuspeed sport springs and just went ahead and bought front and rear SPC kits. Everything is just peachy now. Others said they didn't need camber kits with the prokit springs. You'll just have to wait and see. Just make sure you get them if you are out of spec. A lowered car with major negative camber at the corners just looks cheap and well, stupid.
Anyhow, I like the SPC design for the rear link better than the ingall design. You can get the rear kit, includes both sides, for 124 shipped off the group buy center. 39 for the front set shipped.
Oh, this belongs in the suspension forum. No harm, no foul, just remember for next time. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jul 22, 2002
dezod's Avatar
7thgen Power Maker
i appreciate it guys.....the more the feedback the better......it will be here on wed.....i'll post next week whats going on....
Old Jul 22, 2002
Grey's Avatar
DIY King
Yep. Group buy rear and marketplace front for me was $155 shipped. I sold mine for the same price to another member though. Try the group buy center to get the best price. I would go with the SPC camber kits though. I believe they're of better quality. Although Ingalls isn't bad or anything. I will be getting the SPC when I'm ready to buy a camber kit again.
Old Jul 23, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The SPC kits are like the Eibach (they probably made them). They work great and are indeed tougher than the Ingalls. The ONLY problem I had with them was the ABS sensor on an EX. The mounting method for the sensor was not really that great. Sometimes when you adjusted the turnbuckle the holes did not line up at all and the sensor was not properly routed. The alignment tech did not catch this and I ended up breaking a rear ABS sensor wire. It was not too bad, only 30 dollars for the new sensor and I reset the ABS system myself, but it was a pain getting a new kit. The alignment shop did install the new ones for free and realign the car for my trouble.
If you don't have an EX, then don't worry at all. If you do, then I would recommend the Ingalls.
Old Jul 23, 2002
Grey's Avatar
DIY King
Hey, do you have the SPC's, or the Eibach's? How do you know they have the same ABS sensor bracket? I know they look similiar, but have you seen both of them in person?
Old Jul 30, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
i have to agreee with mbowi have the civics with bad caber, or toe angle. /----\ is tacky to me
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
