Wheels are too fat
Old Jul 15, 2020
Lukarlov's Avatar
Lukarlov is an unknown quantity at this point
Wheels are too fat
Recently bought new wheels and tires from Fitment Industries for my 2002 Honda Civic ex sedan, I got 16s so they would fit without any modifications but the tires I got were a lot thicker and taller than I thought and they rub a lot, there brand new but now there cut up and I can’t return them, I also can’t afford to buy new tires, what should I do???
Old Jul 15, 2020
FRSam's Avatar
Click Here
Re: Wheels are too fat
Wait until you can afford tires that fit.
How badly are they cut up? You may be able to sell them but it obviously depends on if they’re still usable. You could get used tires; I’d personally wait, though.
Old Jul 15, 2020
what size tires you get, what offset, and what suspension setup you got?
I was lowered 2.5-3" (ish) on my 2002 ex coupe and was able to fit 215/45-17s on 17x7 et42 with zero rubbing issues
ideally, you should be running 195/55-16s and the offset on your rims should be within et35-et45
edit: that tire profile will be absolute closest to stock (about 1cm wider) and keep your speedometer pretty much spot on as if you were running OEM tires. Makes me think you got a super high low offset or some huge tire profile
edit2: got my offset directions mixed up. lower offset would put the hub closer to the inner race of the rim, making the wheel stick out farther
Old Jul 15, 2020
Lukarlov's Avatar
They have cut out lines from the fenders and also my the bottom of front springs rest on top of the tire so they’re wear from that too
Old Jul 15, 2020
Lukarlov's Avatar
I have stock suspension and it’s running 16x17 with a 35 offset, I think the rims are good but the tires are the wrong size, should I try to get wheel adapters and go for a wide look or willl it still rub
Old Jul 15, 2020
Lukarlov's Avatar
edit: that tire profile will be absolute closest to stock (about 1cm wider) and keep your speedometer pretty much spot on as if you were running OEM tires. Makes me think you got a super high offset or some huge tire profile
the tires are 235/60R16
Old Jul 15, 2020
Damn. Those are some fatty *** tires man.
edit: I'm not sure rolling the fenders will give you enough clearance. Maybe enough for straight line, level road driving, but hit a bump and you might be rubbing some more
Old Jul 16, 2020
Lukarlov's Avatar
you think discount tire would buy them from me or give me a discount on new ones if I brought those and traded them in and got smaller ones, there almost brand new except for the cuts
Old Jul 16, 2020
BrotatoChip's Avatar
Super Moderator
If the cuts aren't bad someone will probably give you some money for them.
Old Jul 17, 2020
Colin42's Avatar
Discount isn't going to do anything for you since the damage was caused by your own ignorance
Old Jul 17, 2020
bbynams's Avatar
bbynams has a spectacular aura aboutbbynams has a spectacular aura aboutbbynams has a spectacular aura about
Old Jul 17, 2020
Super Moderator
Well that worked about as well as I expected
Morristibbs
Feb 16, 2013 03:07 AM
98_CivicDX
Sep 4, 2012 09:01 AM
QFT
Aug 2, 2012 04:52 AM
Street Kings
Wheels and Tires
Dec 18, 2008 05:51 PM
norweejunwood
Jun 1, 2002 01:22 PM
