Rear Brake pads
Rep Power: 0 Rear Brake pads
I had to replace the rear discs on my 2003 Civic 1.6i Automatic. Regarding the pads, I got two options from Pagid:
In the end I fitted T1263 (that's without the key), brake works perfectly, handbrake works too. The question is: should I get the other type (with the key), could it have been wrongly fitted by the previous owner? Any thoughts from someone who had this dilemma would be helpful.
- T3017 Akebono system, from 01/2005
- T1263 Nissin system, until 12/2004
Re: Rear Brake pads
Pads are already installed and used, you can't return them now. They are working .......so personally I'd leave them in and see if anything unusual happens later on.
Thaik
05-30-2016 05:12 PM
