Drum rub
Old Mar 12, 2016
Scout1's Avatar
Scout1 will become famous soon enoughScout1 will become famous soon enough
Drum rub
Did the front discs on my 2001 Civic. While checking the rear drum brakes I noticed the right rear would rub at one spot as I spun the wheel. The only thing I can think of is the drum is out of round or a wheel bearing issue. Anyway to tell what it could be? It doesn't drag much but I know it must not be spinning perfectly round.
Old Mar 12, 2016
Re: Drum rub
Is it bad enough you can feel it while driving?
THAT'S when it's become a problem.
If it is causing vibration/pulsation issues while braking, you could have the drums resurfaced.
(if you can't tell if vibration is coming from front or rear brakes, try using the handbrake to slow the car to a stop)
If it is not causing vibrations while braking, I would not worry about it.
Old Mar 12, 2016
Scout1's Avatar
Re: Drum rub
I don't feel or hear anything while driving. It isn't bad enough to stop the wheel if I spin it kind of fast it will make the rub sound a few times then stop. Just wondering what would have made the drum get out of round. I guess I will let it go. I have other cars with bigger problems LOL.
Old Mar 12, 2016
Re: Drum rub
Just a sound while spinning it in the air? You won't hear that while driving LOL
As long as it doesn't cause pulsation I wouldn't worry about it
I don't really see drum issues on these even with a ton of rust. Rust buildup might scrape the backing plate, but servicewise they have been very reliable.
About the only thing I've seen that would cause (root cause) drum warp is getting the drums really really hot then setting the park brake super hard.
Gasser22
Feb 20, 2016 06:24 PM
Alexl01civic
Jan 27, 2016 08:56 PM
ray13
Transmission
Jan 19, 2016 06:07 PM
Cheddar
Lighting
Jan 2, 2016 11:57 AM
