Is there an optimal tire/wheel size and offset?
Old 03-01-2016
TranTheDoctor's Avatar
TranTheDoctor is an unknown quantity at this point
I am in dire need of new tires. But I was seeing if I should change my wheel/tire size & width and change my offset while I'm shopping for new tires (I would get new wheels too then.) Asking to see if there are any benefits to these changes or if there happens to be a general consensus on optimal dimensions in terms of fuel economy, ride comfort, etc.
Right now I have a 2003 Honda Civic LX and it has P185/70R14 tires.
Old 03-01-2016
Re: Is there an optimal tire/wheel size and offset?
For economy you may want to check out some LRR (low rolling resistance) tires...but also look at expected treadwear life and take that into consideration.
For ride comfort you'd want stock size.
If you go with large diameter wheels with rubber band tires you will feel every little pebble and imperfection in the road, that isn't comfortable to me. (my Civic is on 18" wheels, I feel everydamnthing in the road)
jdawgzcivic
17
02-01-2020 04:16 PM
bobby08
Electronics
10-19-2015 09:27 PM
samalex
Wheels and Tires
10-07-2015 12:33 AM
thatcham
09-30-2015 08:28 AM
tomas6791
09-11-2015 06:47 PM
Quick Reply: Is there an optimal tire/wheel size and offset?
