Si rims fit on a Special Edition?
Old Oct 29, 2012
cb450sc's Avatar
cb450sc is an unknown quantity at this point
I am picking up a 2005 Civic Special Edition next weekend. It has steel rims and P185/70R14 tires. Will the 15 inch Civic Si (2001-05) rims fit on this car. If so, what size tire should I get so they don't rub?
Old Oct 29, 2012
lowlife9's Avatar
Re: Si rims fit on a Special Edition?
the SI is 5 lug the civic special edition is 4 lug so unless this special edition has a 5 lug conversion no.
Old Oct 30, 2012
canada? no usa civic SE came with anything but 15 inch alloys made especially for that car. the canada SE probably has 14s, and rims from the SI (usa EX) should fit fine if they are 15 inch and 4 lug.
Old Oct 30, 2012
cb450sc's Avatar
They are the 15 inch four lug. Will there be a clearance problem? Thanks
Old Oct 30, 2012
GolNat's Avatar
Prelude Owner
Unless the car is lowered then there will no rubbing or clearance issue. The width of the rim usually affects whether it rubs or not and if its an OEM rim then it wont be too wide.
Old Oct 31, 2012
cb450sc's Avatar
Thanks
OptimisticWay
46
Oct 15, 2015 02:16 PM
califcamper
Jul 21, 2015 10:34 PM
stvpagn
Jul 9, 2015 09:59 PM
