RPF1 16x7 +35 ( 205/50/R16 )
Old Aug 9, 2012
samgodbout's Avatar
samgodbout is an unknown quantity at this point
Hi !
I have a EM2 and I found a set of enkei RPF1 16x7 +35 offset.
The tire on the wheel are 205/50/R16
does everyone know If that will rub in the front or in the rear or in the front and rear ?
I don't want use the fender roler, so if i need to rolle my fender, I will cancel the project to buy RPF1.
thanks a lot !
Old Aug 10, 2012
samgodbout's Avatar
Re: RPF1 16x7 +35 ( 205/50/R16 )
nobody ?
Old Aug 11, 2012
sl33pyriceboi's Avatar
It shouldn't rub. I was running a similar setup and I was slammed
Old Aug 11, 2012
samgodbout's Avatar
nice thanks a lot !! i will run slammed the nest summer, so that need to pass
Old Aug 15, 2012
EcoRacerD17's Avatar
EcoRacerD17 is an unknown quantity at this point
Sounds cool, those RPF1's are soooo nice! I've heard they rust easily though, so definitely keep them maintained!
Old Aug 16, 2012
Whoever/where ever you heard that is COMPLETLY false. They are made of aluminum (hence why they are so light)... And aluminum doesn't rust.
Now, fake/replica rpf1 are a different story
Old Aug 27, 2012
samgodbout's Avatar
I wanted to be sure if that do not rub. So I decided to going to see the EM2 with the RPF1.
In the front , It's OK
In te rear, It's OK with a lot camber. If I wanted my wheel with no camber, that rub. So I decided to not buy it.
The best, It's 16x7 with offset 42. After that, you can add spacer that you want.
Old Aug 28, 2012
Did you take into account you can roll rear fenders
Tedverseti
Apr 23, 2020 01:45 PM
doncarbone
Jun 8, 2015 03:37 PM
ramcosca
Oct 16, 2005 09:55 PM
Roo
May 4, 2005 07:08 PM
sw388integra
Sep 2, 2004 02:31 PM
