17 or 18's on a 2" drop
Live for the Twisties
Re: 17 or 18's on a 2" drop
Either will work fine, it mostly comes down to personal preference. The larger you go the more expensive tires will be and the lower the selection of wheels will be, since above 16" 4x100 becomes an odd size.
Just keep in mind that 18"s will ride rougher and you'll have to pay closer attention to your tire profile to make sure it will fit. There's less selection with 18"s too.
word of warning: i hope u know what you are getting yourself into. koni is a reallllllllllllllllllllllllllllllllllll b1tch to install...
also, im riding on 18's and the ride is rough. i cant tell how much of it is from the blown out stock struts.
And my uncle was a mechanic so I was going to have him help me
But would tokico blues work with neuspeed springs? On the 2.24 drop
definitly a modder's job if ur up for it. but its damn worth the performance.
koni yellows > tokico Dspec > koni STr.T > tokico blues > KYB
hey also have lifetime warranty on them.....so make sure you buy it form an AUTHORIZED dealer... ebay is not an authorized dealer...most of them lie.
http://www.autoanything.com/ is where i got mine. cheapest place online.
and if u sign up for their emailing list, they will send you exclusive discount codes for up to 25% off. which makes your yellows even CHEAPER
i ordered my GC directly from eibach because (if you do research) you will want to ask them for a 6" rear spring in the else you will kinda bottom out (especially if you have a sub in there). you will have to look at boilmarker's thread:
*note: read the end of his guide and he will talk about the rear 6" spring.
https://www.civicforums.com/forums/4...-finished.html
and here are a few install DIY just to show u what you will have to do:
http://www.hondatuningmagazine.com/t...ion/index.html
http://forums.nasioc.com/forums/show....php?t=1219607
4" drop doesnt mean your 4" from the ground it means you've dropped 4" from stock height right?
My 04 EX is 4.25 inches from the ground in the front and 4.5 inches in the back. I dropped about 2.75 inches from stock in the front and 3 in the back on my Pro S II's. Both of my fenders are 24" and 24.25" from the ground.
I would say I have about a 3" drop all around (nice and flush
) Banished to the Depths of Rice.
from what i hear, Dspec is a decent coilover...but not as strong/well built as the yellows.
the Dspec is also a direct swap for the 7th gens. no cutting or drilling.
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
