Brake lock-up issue
Old Mar 17, 2012
iridehonda's Avatar
iridehonda is an unknown quantity at this point
Brake lock-up issue
For a couple months now my driver's side front caliper will get stuck against the rotor. It seems to happen somewhat randomly. If I use the brakes a lot the pedal will eventually get stiff and cause it to lock up (only the driver's side front). Sometimes I will shut the car off without it being locked up and it is locked up eight hours later when I go to leave. I have replaced both front calipers thinking that might be the issue, which provided no relief. If I stomp on the pedal a few times it seems to relieve some of the pressure but a couple more uses of the brakes locks it back up. I am at a loss as to what it could be and would like some opinions before I jump into replacing the master cylinder and/or brake booster. My car is an 02 EX. Any input is appreciated. Thanks guys.
Old Mar 21, 2012
04 Honda Civic's Avatar
Re: Brake lock-up issue
Did you grease the slide pins on the new caliper?
Replace/bleed the fluid see if that helps.
Old Mar 22, 2012
maxtierney's Avatar
EM2ti
Check your hoses, if 04 Honda Civic's advice doesn't help. Internal failure sometimes causes pressure to be retained in the hose.
Old Mar 27, 2012
iridehonda's Avatar
Sorry for the late reply. Following advice from another site, I replaced the hose and everything is working fine now. Thanks for the replies guys.
Old Mar 27, 2012
What was wrong with the hose?
Bleed the fluid (All 4) anyway. If you get alot of moisture in the lines, the pistons inside the calipers will eventually seize up.
Old Mar 29, 2012
iridehonda's Avatar
I'm guessing it was collapsed and not letting the fluid back through it. It looked fine to me though when I pulled it out. Can't really say what was wrong with it. I bled all four and everything is working fine now.
Old Mar 30, 2012
iridehonda's Avatar
Update: The problem is back. After working fine for a few days I just got home and my brakes were smoking and sure enough, it's locked up again. Any other ideas on what it could be?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
TiggerDX
Jun 18, 2015 01:43 PM
McD
Apr 29, 2015 03:50 PM
Sparty
Nov 15, 2001 04:55 PM
