Tire Selection HELP
Old Jan 9, 2012
DtaWat's Avatar
DtaWat is an unknown quantity at this point
Tire Selection HELP
Okay, I am looking to get new tires and rims. I want a larger and wider tire than my current Nitto 225/35/r19 tires and a smaller rim. I have an 03 civic EX.. heres a pic Name:  leetersaucer.jpg
With the 225 on 19 inch rim I really don't have any rubbing, maybe once in a blue moon.. but for the most part none. I want to go with a Firehawk Indy 500 size 235/60R15. My main reason for switching tire is for more comfort and avoide feeling/ turning into every damn bump or hole in the road. But, I still want somewhat of a performance type tire. Also, I think wider tires look alot better.
I would appreciate any advice/comments.
Thanks!
Old Jan 9, 2012
DtaWat's Avatar
Re: Tire Selection HELP
I would really appreciate some help selecting my new tires. I am looking for a good looking wide tire that supports a comfortable ride without substuting performance.. Would Firehawk Indy 500 (235/60/R15) be a good choice?
Old Jan 9, 2012
MindBomber's Avatar
Live for the Twisties
235 is ridiculously wide and totally unnecessary, it may look good, but it adds a massive amount of rotating mass.
Old Jan 9, 2012
DtaWat's Avatar
Could you go into more detail? 235 isnt much wider than my current 225's. would the extra width be much of a difference as far as normal hiway and city driving is concerned?
Old Jan 9, 2012
MindBomber's Avatar
Yes, tires are really heavy man, they're even heavier than the majority of wheels.
Check the weights by pulling a shipping quote, you'll be shocked.
Old Jan 9, 2012
DtaWat's Avatar
Maybe 235/50/15 would be better? Or is 235 width tires just overall a bad idea for a civic? How will it affect daily driving?
Old Jan 9, 2012
which nitto?
indy 500? performance?!?
Old Jan 9, 2012
sl33pyriceboi's Avatar
why dont u get smaller rims and some stickier tires... like some falken azenis 615 or something...
getting wider tires and getting shitty as tires like the indy500 will not benefit you. (and why else would you want to go wider if u dont want extra grip/traction)
hell, some falken azenis in 205 width would out grip your indy500 with a 235 width
Old Jan 9, 2012
a rule of thumb, the higher the treadwear, the less grippy they are (but the more miles you will get out of it).
so ur firehawk indy500 has a treadwear rating of 500, which is very high.
the faken azenis has a 200 treadwear.
Old Jan 10, 2012
DtaWat's Avatar
I'm looking for a tire for more of a comfort and quiet ride as well as being thicker and wider than normal for appearance.
Old Jan 10, 2012
DtaWat's Avatar
Maybe a Bridgestone Turanza 225/60/16 would be a better choice than the Firehawks?
or Firehawk Wide Oval Indy 500 225/55/16?
Old Jan 10, 2012
but you have 19" rims...
if u wanted anything remotely of a quiet ride you would have gone no larger than 16 or MAYBE 17"
adding wider tires will not give u a quieter ride. u need to add profile but since u have 19" rims, ur profile options are very thin....
/pun intended.
Old Jan 10, 2012
and if u do go 15" rims, you are going to have to get a very very wide 15" to fit a 235 on there... at least a 7.5 or better yet an 8" wide rim.
Old Jan 10, 2012
most 15" rims are either a 15x6 or 15x7 rim.
idealy, you want a 205/60/15
Old Jan 10, 2012
either of them are better, but turanza is not exactly performance either.
wide oval is more performance oriented than the turanza (which is more "luxury" brand).
Heck, did you even bother to go to the tire rack site and simply read around a little bit?!?
Old Jan 11, 2012
DtaWat's Avatar
Went with the V rated Cooper CS4 Touring 225/50/16 tire and American Racing Santa Cruz chrome rim.
Old Jan 11, 2012
post pixs of the time/tire and them on the car.
what size as ur rim? 16x?
alaga
25
Aug 13, 2015 04:42 PM
EngiNERD
Aug 12, 2015 09:20 AM
carid
Aug 8, 2015 05:05 PM
jedi
Aug 3, 2015 04:26 PM
