Brake and clutch issues??
Old Aug 17, 2011
brobo's Avatar
brobo will become famous soon enoughbrobo will become famous soon enough
so after reassembling my car and drive , the clutch is super easy to press down and it shifts perfectly ,so i bled it and still same issue, what do u think??
next my brakes work fine after bleeding but its so scary driveing it because you have to press the brakes almost all the way down for them to stop the car, what can i fix to resolve that??
Old Aug 17, 2011
Matt300's Avatar
Matt300 is an unknown quantity at this point
Re: Brake and clutch issues??
I don't think you have to worry about the clutch. I just replaced the stock clutch on my '05 LX with an Exedy, and it's super easy to press the pedal down now. It took about an hour of driving to get used to it, but I'm loving how quick and easy it is to shift.
As for the brakes, not much I can say except that it's not supposed to go that far down. If you're sure the brakes were bled correctly, then have you checked out the lines for holes? How about the caliper? Just some top-of-the-head ideas, but I'm sure someone will chime in with a more specific answer.
Old Aug 18, 2011
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
If the brake pedal is going almost down to the floor it is usually one of two things, air in the lines or the rear brake shoes are misadjusted.
Front disk brakes are self adjusting because the pistons in the calipers move out as the pads wear and the pads are always floating on the surface of the disk. Drum brakes have springs that pull them back when they are not applied so if they are not adjusted correctly the distance the pads have to move before contacting the drum will cause the travel in the brake pedal.
You can usually test if it is the rear brake shoe adjustment by setting the parking brake and seeing if the pedal travels less (This is while parked). The setting of the parking brake is moving the shoes out to contact the drum the same as the adjuster should, so after you press the brake pedal the first time to push the wheel cylinder out, there should be no play in the system.
If the rear brakes need adjusting, make sure that the ebrake is completely released and then adjust the self-adjuster inside the drum, don't just adjust the ebrake cable.
Old Aug 18, 2011
pjb3's Avatar
Also, if all you did was bleed the brakes and and the pedal travel was fine before then you probably still have some air in the system.
Old Aug 19, 2011
brobo's Avatar
yea i just adjusted the brake pedal and it works great but for clutch i got it to be low now but still pretty light to press
Old Aug 19, 2011
dAxRiceburner's Avatar
dAxRiceburner is an unknown quantity at this point
My buddy had the same problem as you do. We just assumed it was air in the system but turns out it wasnt. It took us a while to actuallly figure out what was wrong. Turns out my buddies brake line had a small hole in it. Id go over your brake lines and see if they have a hole in them. If not im not sure what else it might be. But someone on this forums has to!
Old Aug 19, 2011
brobo's Avatar
i adjusted it and now it works super great and grips from top and the clutch was also adjusted to be lower but its still easy to press
Old Aug 19, 2011
Thats good, im not sure what would be causing it then. But the best of luck to ya. hope you figure it out bro.
Old Aug 19, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
You may want to look at your clutch SLAVE cylinder. It's attached to the front of the transmission, generally that's what you will bleed. Make sure there is no fluid around the rubber boot on the cylinder. It could be faulty, and is one place that air can get into the system.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
McD
Apr 29, 2015 03:50 PM
bsmiley
Apr 27, 2015 01:27 PM
JoeB16
61
Oct 16, 2003 07:58 PM
02EXCoupeGuy
Dec 19, 2001 09:47 PM
