New brakes grinding on hard left turn
Hello everyone, new to the forum and I could use your advice. I just changed the rotors and pads on my 2003 civic hybrid, I installed EBC 850 rotors and green stuff pads. Everything seems to work well, they dont squeek at all, but it appears that the passenger side front grinds on hard left turns. I have rechecked the pads and the rotor and cant see any evidence of rubbing etc. Nothing on hard right turns or straight line travel. Any advice?
Thanks Ryan
Thanks Ryan
Re: New brakes grinding on hard left turn
check your dust shield, you may have bent it a little, jack the car up,take that wheel off, turn the steering wheel all the way to where it is when you hear the noise as your driving and spin the rotor, listen to hear if you hear the noise and pinpoint where its coming from
Im a Senior Member. Take that Noobs!!
dust shield possible but i would look into a possible hub bearing. Put the front in the air and try and jiggle the tire top to bottom if it feels loose go get a new hub
up and down can also be ball joints, upper or lower, if it has play side to side and up and down, and your tie rod ends are tight and the ball joints dont have any visible play, it may be the bearing, but it shouldnt grind as your making a hard left turn, it should make a consistent howling, thats the verbal symptom of a wheel bearing
same happened on my last brake change (oem pads and brembo rotors). i still have the grinding years later and nobody could find the problem. "looks normal" they say. bending the shield didnt work. next time i will just take it off.
Thanks guys, it was the heat shield. I actually had to pull it toward the rotor to keep it from grinding on the turns. It is about 1/8 inch off the rotor and all works fine now.
Thanks for all the help!
chuffsy
May 15, 2015 12:50 PM
edgenet
May 2, 2015 08:00 PM
GH04si
Apr 15, 2015 08:13 PM
