Brake replacement
Old May 1, 2011
ongfufu's Avatar
ongfufu is an unknown quantity at this point
Brake replacement
hey guys, i live in canada and have a 2001 civic and have had it since new. so i've been driving this car for 10 years, and never replaced the brakes. the car has about 103000 kms on it, and i've been told by many friends that i should've changed brakes loooong time ago. but every mechanic i've asked says i still have 60-70% life left on the brakes (the dealer says 70%). should i replace them just because of the time/age?
thanks in advance
i should add that i don't drive like a granny, i'm still young so i hit the pedals harder than average people.
Old May 1, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: Brake replacement
Keep running them until they need replacement... At that many kms when you do replace them make sure you get new rotors too... That's some great brake life. Now, your sure they are checking your fronts not rears? Rears last forever, the fronts tend to wear down.
Old May 2, 2011
CraigW's Avatar
How about other maintenance ? Like the brake fluid change ? Should be done every 3 years.
And yes, rears I could see still o.k. not fronts.
Old May 2, 2011
BlueEM2's Avatar
Whachya lookin at?
Well... I do all highway any my OEM brakes laster 105k kms... second set substantially shorter only 60k i think. I cheaped out though
Old May 2, 2011
CraigW's Avatar
So sorry, it was a miles vs kilometers mix-up.
Old May 3, 2011
BlueEM2's Avatar
Whachya lookin at?
Hell even 60k miles is a lot on brakes... moreso for automatic than manual though.
Old May 3, 2011
ongfufu's Avatar
The rears are 70 and the fronts are 60, if i remember correctly, if not then vice versa. I do remember Honda says i got 8mm left from the front.
Old May 3, 2011
ongfufu's Avatar
I do mostly city, maybe 100km trips once every 2-3 weeks.
Old May 3, 2011
ongfufu's Avatar
Yes I've changed brake fluid accordingly.
Old May 3, 2011
8mm? fugget it then. just the fluids
Poopies
Apr 20, 2017 11:36 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
