6 shims on OEM brake pads?
Old Mar 29, 2010
g2s's Avatar
g2s
g2s is an unknown quantity at this point
I just bought new OEM brake pads for my Civic 2001. It includes 3 different shapes. 2 shims per shape. What is the correct order to install these 3 different shims?
Correct me if i am wrong:
1. bottom shim (see photo) is for brake pad with NO metal wear indicator
2. Top 2 shims (see photo) is for brake pad with metal wear indicator. If both 2 top shims are required, which shim is next to the back side of the brake pads?
If only 1 shim is required for each piece of brake pad, is brake grease required on BOTH shim's surfaces (surfaces that touch brake pad and piston) ?
Thanks
By atsiv at 2010-03-29
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
hayden55
Jul 8, 2015 11:38 PM
Causemo
Jul 5, 2015 06:42 AM
hatch90
Jul 5, 2015 01:17 AM
