SILLY QUESTION but need an answer !!!
Old Sep 12, 2007
kLouD's Avatar
kLouD is an unknown quantity at this point
this is a silly question but does it really matter if you're rockin mismatched sized rims? tires? more specifically, three 15" steelies and i have a 14" steelie left but is it safe to drive for awhile? i drove with two 15" in the front and two 14" in the back and it wasnt that bad? but three 15" im a bit sketchy about. tell me your thoughts. thanks.
Old Sep 12, 2007
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Re: SILLY QUESTION but need an answer !!!
Correct me if I'm wrong, but doesn't that mean your car front is at different heights, where the 15 side is higher than the 14? Additionally, the amount of distance you cover per wheel rotation is different depending on the wheel size. The circumferences (distance traveled) of each wheel will be different every time the tire rotates.
Old Sep 12, 2007
sl33pyriceboi's Avatar
as long as the two front tires are teh same size rim and tire size...
and as long as the two rear tires are teh same in tire size and rim size,
then ur fine for now...
but running on 3 15" and 1 14" is unsafe and it willl cause ur car to be imbalanced...
and when your turn too fast, you could lose control n crash...
Old Sep 12, 2007
Kevbotron's Avatar
I like my commute
^truth.. oh and that's in the manual too
Old Sep 12, 2007
greeen01civic4d's Avatar
yea, keep same size on each axle, i see this all the time down here, and its so unsafe, and stupid, plus itll **** ur good tires, cuz it changes the weight balance towards the smaller one
Old Sep 13, 2007
kLouD's Avatar
the difference in rim size is logical but does the tire size really matter that much? 185/65 to probably a 195/60? because currently as of now, im rolling on three steelies and a gsr blade. two front steelies are 185/65. third rear steelie is 195/60 and the gsr blade is a 195/55. let me know. thanks.
herbiej
22
Aug 23, 2015 01:02 PM
sccarally
Texas
Aug 21, 2015 10:09 PM
civic98?
Aug 13, 2015 01:32 AM
spyder13
Jul 31, 2015 06:31 PM
NoobyKid
Jul 13, 2015 07:53 AM
