Newb question on different tire sizes
Old Aug 10, 2007
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
ok so right now i have some 205/55r16 on my car. i bought those tires with rims already on them. my question now is, will any 16 inch tire fit my rim? eg 215/55 or 205/50, etc etc? what diff would that make?
Old Aug 10, 2007
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
Re: Newb question on different tire sizes
Any 16 inch tire will fit on the rim. For 215/55/16, the first number is 215mm(width of tire) and second number, 55, is the aspect ratio or sidewall height. The 55 denoting that it's 55% of 215 mm.
Old Aug 10, 2007
karizzle's Avatar
Pinkslip Racer
ok so no matter what, as long as the tire is 16 inch (aswel as my rim) there wouldnt be a problem (fitting, driving etc)
Old Aug 11, 2007
buckshizzo's Avatar
There wouldn't be a problem fitting on the rim. The only problem I can see is how low the car is because there might be an issue with rubbing the fender. The wider you go the better traction you get due to the increased surface contact area, but in turn, it also increases your chances of hydroplaning in wet weather.
Just remember, a good rule of thumb is the wider you go in width, you want to compensate by going down on the sidewall by 5%. This is called plus sizing zero. For example, your current size is 205/55/16 and you want to go wider. You would get a 215/50/16. Also keep in mind that some tire sizes aren't all that common, so expect to pay a little more. I would recommend staying with your current tire size. It's a good size for a 16 inch rim on a honda civic.
Old Aug 11, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
go here. it will compare the tire sizes for u
MN-02-CivicEx
Jun 25, 2015 08:32 PM
bo_red
Apr 23, 2015 10:09 PM
NightKids2
Dec 8, 2001 05:50 AM
supercivic01
South
Nov 30, 2001 11:27 AM
