Car is aligned but still drifting?
Old Jun 8, 2007
Atticus's Avatar
Atticus is an unknown quantity at this point
So i wen't and got the car aligned everything was good and car is still drifting at 60 mph and above. Problem didn't start untill I had my old (not on the car anymore) tires rotated.
I'm on 4 new tires, all balanced, aligned, and properly inflated and the car drifts and pulls.
Brought it to honda with the TSB and they said that the steering wheel was a little off but couldn't duplicate it.
They are ordering parts for 3 other TSB's so when I bring it back I'm going to have them re drive it on the highway and hopefully they will order whatever steering parts are necessary.
or maybe I just need to re rotate the new tires.
TSB number for the pull drift is 06-068 for those interested.
Old Jun 8, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Re: Car is aligned but still drifting?
what lane are u in when u drift..
Old Jun 8, 2007
wheelspinLX's Avatar
wheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nice
Most roads have a crown in them which means the middle of the road is higher than the outside edges of the road. So my car is perfectly aligned and all stock, it will pull toward the edge of the road because of the crown in the road. So a little pull cant really be avoided, but if your is in the right lane and the car pulls pretty hard to the left you definitely could have a problem.
Old Jun 8, 2007
greeen01civic4d's Avatar
u may be getting what is referred to as a "radial pull" which does tend to happen, u may have a bad tire, but i agree about the crown in the road. get ur tires rotated, and if the problem still exists, then have honda check the tsbs for a potential problem
Old Jun 8, 2007
Boggie6868's Avatar
Boggie6868 should not be trusted
Ever been in an accident?
Old Jun 8, 2007
LT2004ever's Avatar
i was about to say pertty much all roads are built on a slant, to allow proper sheeting/drainage of H2O wheelspin beat me 2 it
Old Jun 8, 2007
Atticus's Avatar
no accidents.
It happens in all lanes mostly prevelant on highways in any lane at speeds of 55mph and it gets worse the faster you go.
I can also feel it when under hard braking.
Never had a problem with it previously - I'm afraid to really get on it becuase I don't want to lose control of the car.
It just won't hold a straight line and when you go to correct it does so more than you intend it to so it starts sliding.
Old Jun 8, 2007
Boggie6868's Avatar
Ok if I understand this correctly you rotated your OLD tires and this problem occurred. You tried to remedy the problem by getting new tires, having them balance, and the whole car aligned.
Right? This helps us eliminate the fact that it might be the new alignment, or tires.
Have you checked your pressure by any chance?
Old Jun 9, 2007
Atticus's Avatar
1) went to the dealership for and oil change and rotate. Realized that the fronts where almost bald. had them rotated to the back.
2) had 2 new back tires (old fronts) put on as well as matching fronts. 4 new tires balanced and proper pressure.
3) had an alignment - numbers weren't off by much to begin with and also found out about the tsb for the pull and drift.
4) went to the dealership with the tsb and they said that the steering wheel was off by a little but coulnd't duplicate the problem.
5) I'm giong back to have 3 more tsb's taken care of and they are going to re test it.
The problem only started after the first rotate to put the almost bald stock tires on the back. The rear end was sliding everywhere so I just went and got 4 new tires. They are yokohama as430's.
I'm just trying to determine if it is the TSB or if theres something else that might be causing it.
Old Jun 9, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
so does the car start to fish tail, or does the back end feel like it is going to swing around? and if so does it always start to go to one side? and is it when ur going straight, turning or all of the above?
Old Jun 9, 2007
Atticus's Avatar
It's not the back that's drifting on me, it's the front. The back was moving on me when it had the crap stock tires on it.
this is straight line on the highway.
Old Jun 9, 2007
Boggie6868's Avatar
Ok well from what I understand after the first rotation you had bald rears. This would account for the sliding around and such, especially if roads are dirty.
Now that you have new tires all around, there should not be any sliding. Do you have any modds on your car? specifically suspension modifications.
Now you had the car realigned after the new tires were installed?
"had an alignment - numbers weren't off by much to begin with"
But did the alignment fix the numbers? Are you in red at all after the alignment? If you are red at all, that might be the cause of your pull or drift.
Even if you are in green it doesn't mean its going to go straight. When you have your car aligned to spec, it just means tire wear is acceptable by the factory. If done correctly the tires should be parallel, but sometimes they don't spend enough time on the alignment. They just get it into spec, but don't bother to make sure all the wheels are parallel. This will also cause the drift or pull.
Sounds to me something is wrong with the alignment. You sliding with the old tires may be due to the bald rears. Now the new tires shouldn't slide, but your getting a pull or drift due to a possible bad alignment.
Do you have the print out?
Check your front toe...I think that might be the problem.
Old Jun 10, 2007
tfnaaf's Avatar
BLDNPSI Mod
im betting $$ on its a bad tire causing a radial pull as stated in an above post
Old Jun 10, 2007
chinaman's Avatar
chinaman is an unknown quantity at this point
Hey did you check your front caliper/pins, it will make your vehicle pull/drift if they are stuck/sticking. It defintily could be the alignment (front toe), if you have the print out post it. And the only other thing i could think of is a bad tire (bad belt in tire).
Old Jun 10, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
check your tire pressures. if one tire has significantly less air, it will have a larger contact patch, which will cause more drag, and pull the car in that direction
Old Jun 10, 2007
sentbacktothesu's Avatar
sentbacktothesu is an unknown quantity at this point
it could be a front brake bad hanging. if the brake is sticking even the littlest bit, you might not notice it at slower speeds but on highway you'll notice it. my truck used to do that. i would notice it more on the highway and especially when i came to a stop anywhere.
Old Jun 10, 2007
Boggie6868's Avatar
I doubt its your pad. They don't touch your pad or your disc when they do an alignment. No to mention if you had a front brake pad that was rubbing, it would smoke after a few miles from constant friction and you would definitely smell it. It could be, but I highly doubt it.
Old Jun 10, 2007
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
def get all the bushings in the front checked out. i'm 99% sure its some worn bushings causing the problem. check them out before spending alot of money on other ****. specialy check the radius arm bushings on the side that the car is pulling to.
Old Jun 21, 2007
Atticus's Avatar
Took the car in to take care of 3 tsb's that they order the parts for. I'm getting them to do an alignment as well. This is my home dealership and has always given me good service with no b/s. Comes with a 12 month 12000 mile warranty. I'll let you know how it goes when I go to pick it up.
Old Jun 22, 2007
Atticus's Avatar
*Edit
Old Jun 22, 2007
Atticus's Avatar
Right, so the second alignment fixed the problem. no more drifting at highway speeds and all that good stuff. Car pulls to the right now when steering wheel is straight though so I think I'm going to have to take it back and make them fix that.
numbers are :
FR: Camber -0.5
Toe 0.9
FL: Camber 0.2
Toe 0.9
RR Camber -0.7
Toe 0.9
LR Camber -0.9
Toe 0.9
As an added bonus they replaced the gauge assembly to fix the gas light but didn't correct my milage. So I have 36,xxx less miles when I go to sell my car down the line.
Old Jun 22, 2007
Alpha 5's Avatar
What was your mileage before?
Also a little drift to the right is fine. They say that if you are driving and fall asleep that the car is to vier off of the road instead of into oncoming traffic. So I am told.
Old Jun 22, 2007
MrXclusivE's Avatar
or into the pedestrians
Old Jun 22, 2007
Alpha 5's Avatar
Well, since the majority of driving is on the Highway there should not be that many pediastrains around. Besides I would hope that the pediastrains would be awake and able to jump out of the way. That is if they are not too fat. Wait a minute. I don't think the fat ones do the walking, they are the ones sleeping in the car.
Old Jun 22, 2007
MrXclusivE's Avatar
u mean like this; lol
http://www.youtube.com/watch?v=Zeo-3PLIFzw
Old Jun 22, 2007
Alpha 5's Avatar
LOL, YES JUST LIKE THAT. haha +1 4 u...
Old Jun 22, 2007
Atticus's Avatar
I had 36,7xx on the car. I now have 40 miles. Car rides nice and drives a lot better.
Xuhme
21
Aug 7, 2023 03:40 PM
oneheadlight
Apr 29, 2015 11:30 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
ImmortalEX
Oct 31, 2001 10:00 PM
