Hawk HPS Questions...Strange Tab
Old May 16, 2007
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Hey Everyone,
Ok so I need to install my new hawk hps pad because my oem pads are starting to run low.
My question is what are these strange tabs for on the hawk hps pads?! I haven't removed the oems yet, because I don't wanna go through the trouble of taking it all apart and realizing I have the wrong pads. (these new pads should be the right ones though)
Also, I heard from some miata owners that the hawk hps pad shims can cause problems with the braking system. Has anyone had problems with the shims on the civics? I'm debating whether or not to remove the hawk ones and use the oem ones.
ID:	71101   Click image for larger version
Old May 16, 2007
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Re: Hawk HPS Questions...Strange Tab
they will fit perfectly, those clips let you know wen your brake pads are
done for the job.Oem one have just the same 2 clips.
Old May 16, 2007
Boggie1688's Avatar
Diamond Member
Thanks for the quick reply!!!
Old May 16, 2007
DsevenEm2's Avatar
This is Myspace
mazdam miata and honda civic are not the same car. im sure the shims will work fine. i havnt herd nothing but good things from hawk pads for our cars. i plan to get some too when i upgrade my rotors late this summer.
Old May 16, 2007
idk, my new oem pads in the closet here look just like those.
Old May 16, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
yea they are for the back side.
just slide right in, i just got done replacing mine a day or so ago, and i have nothing but appraisals for the hawk pads.
Bruce2
Sep 27, 2015 08:45 PM
Sep 27, 2015 11:33 AM
naokigoffi
Aug 30, 2015 06:19 PM
theteju
Aug 5, 2015 06:59 PM
DerbyDad03
Jul 27, 2015 11:34 AM
