Help with this brake diagram!
Old May 9, 2007
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Hey everyone,
I'm trying to figure out where number 7 hooks up to the car.
Anyone know?
Thanks!
Old May 9, 2007
MURDOCK's Avatar
My cats breath smells like cat food.
MURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond repute
Re: Help with this brake diagram!
Looks like it hooks to number 4 the master cylinder.
Old May 9, 2007
Alpha 5's Avatar
I agree
Old May 9, 2007
Boggie1688's Avatar
Diamond Member
Where is that master cylinder on the car? Do I have to remove the cylinder to get to the top of it?
Old May 9, 2007
MURDOCK's Avatar
Its connected to the brake resivoure under the hood by the steering wheel it is full of brake fluid.
What is it you are trying to do?
Old May 9, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
9 and 10 connect to the master cylinder. It either connects to the proportioning valve or the ABS block. Get a shop manual not a parts diagram and figure it out.
Old May 9, 2007
MURDOCK's Avatar
If you plane on mucking about with brake fluid be very carfulle not to get it on the paint, it will remove it.
Old May 9, 2007
MURDOCK's Avatar
ya I would agree since it is connected to brake pedal.
Old May 9, 2007
Alpha 5's Avatar
Here is a pic
Old May 9, 2007
Alpha 5's Avatar
and some more
ID:	71029   Click image for larger version
ID:	71030   Click image for larger version
Old May 9, 2007
Alpha 5's Avatar
one more
Old May 9, 2007
mr_fobster's Avatar
yea mang the only difficulty i see you in doing this is reaching down to the prop valve and trying to unscrew that rear brake line off....its gonna be a little tough with little to no space.
Old May 9, 2007
Alpha 5's Avatar
^^^What is he trying to do?
Old May 9, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Originally Posted by Alpha 5
Here is a pic
hey in that pic did u just clean ur engine bay by using degreaser and spraying down??
sorry to get off topic
Old May 9, 2007
Alpha 5's Avatar
That pic is old, but I would go to the car wash and use the green tire cleaner on the engine then use the rinse at a distance. Water will not hurt the engine the psi will. So when you rinse it dont bare down on anything that can be damaged. Pm me if you have any other questions. Don't want to ruin the thread.
Old May 9, 2007
Jap-Euro Fusion
Oh and one more thing... while I have no idea why that line needs to be disconnected... use a FLARE NUT WRENCH to remove it. If you use a regular wrench you will strip it, and then you will be up **** creek.
Old May 10, 2007
Boggie1688's Avatar
Diamond Member
I stripped the side that connects to the rubber hose for the rear drum. So I want to replace the line. Im guessing I stripped it because I didn't use a flare nut wrench.
Old May 10, 2007
Jap-Euro Fusion
thats a rediculously excessive replacement to fix the nut. Go to Autozoo, buy a 1' section of brake line with the fittings on it (maybe $5). Just get the piece thats the right diameter with the longest threaded nut they have. Cut it off, cut the flare off the stock line, get a double flare tool, put the nut on and reflare the line thats on the car. OR, if you never intend to take it off again, grab the damn thing with vise grips, tighten it up and leave it be.
Old May 10, 2007
Alpha 5's Avatar
I agree this is a little extreme for a stripped nut. Just do what Boiler said, cut the line then put a new fitting on it then flare it and you are done. Don't say you cant flare it because flaring the end is way easier than replacing the whole damn line. It is also way cheaper and you can keep the tools you use. That way in the future if you want to do a return fuel line or some other mod with copper pipe you will already have the tools.
JUST MY .02.
Old May 10, 2007
Boggie1688's Avatar
Diamond Member
I might just try to use a vise grip.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
cncnut
Aug 23, 2015 01:25 PM
horta1212
Aug 22, 2015 08:31 PM
Low_Lupe
Aug 17, 2015 10:57 AM
honda.lioness
Aug 6, 2015 11:58 AM
