01 civic brakes
Old Oct 26, 2006
hcivic0120's Avatar
hcivic0120 is an unknown quantity at this point
01 civic brakes
i have a 2001 civic ex and i think my brakes are getting bad. I had new brakes in the front done not to long ago. Just recently evertime i release my brake like when im going to take off, it squeeks, is this from the front brakes or rear. The rears are drums. Anyone know y. Thanks.
Old Oct 26, 2006
CraigW's Avatar
If the person who installed the brakes did not use an application of some sort of disc brake quiet when installing pads.... it could be the fronts.
To maybe test if it is the rears use the hand brake on/off/on/off and see if the noise occurs then. May work, may not.
Old Oct 26, 2006
rutscivic's Avatar
rutscivic is an unknown quantity at this point
they coulda used hard lining
Old Oct 26, 2006
Zzyzx's Avatar
Autocross Junky
Squeaking from letting go of the pedal is from the rear drums. It just means that the pivot point of the shoes or the spring could use a little lube, no big deal.
Xuhme
21
Aug 7, 2023 03:40 PM
Poopies
Apr 20, 2017 11:36 PM
McD
Apr 29, 2015 03:50 PM
bsmiley
Apr 27, 2015 01:27 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
