alignment or defective tires?
Old Oct 20, 2006
blk04civiclx's Avatar
blk04civiclx is an unknown quantity at this point
So I just bought some g-force pro series tires from costco.. And ever since I bought them whenever i'm driving on the freeway, my car sways back and forth like im driving in high winds... what u guys thinK?
Old Oct 20, 2006
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
check the tires they might be defective, you might have radial pull or something. Rotate the tires and see if it still does it; if it stops swaying, then it's the tires. if it still sways after the rotation, go get the alignment checked.
Old Oct 20, 2006
Zzyzx's Avatar
Autocross Junky
Are you running the same width tires as before? stikier compounds?
Freeways have grooves cut in them to help drain water, these grooves arent perfectly straight.... And wider tires as well as stikier tires have a tendency to grab these grooves and follow them... its called Tracking.
Old Oct 20, 2006
its the same width as my stock tires i guess the new tires are stickier but it feels like i'm going to lose control of the car anytime.. its kinda scary lol
Old Oct 25, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
like zzyzx said, but it might also have something to do with the tread patterns gripping the grooves as well. from what it sounds like you're saying is that your car rocks side to side as if driving on wobbly wheels/suspension, rather than the tires grabbing on to the road, but i dont know. maybe something to do with wheel balance? how's tire pressure?
Old Oct 25, 2006
Synapz's Avatar
Synapz is an unknown quantity at this point
i would definately check ur alignment as well...
Old Oct 26, 2006
i believe it is the tracking like zzyzx says beacause it only happens when im on the freeway not on paved road. In any case im gettin new tires because it is really annoying and doesn't feel safe..
Old Oct 26, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
Did they balance your wheels?
Old Oct 26, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
are you running stock rims? if so are there weights on the outside of your wheel? if not then you might want to go back and have them rebalanced. if you have aftermarket wheels then have them balance it on alloy 2. this will put sticky weights on the inside of the wheel near the spokes and a weight on the inside of the lip. might save some money rather than buyin new tires. let me know how it works out.
Old Oct 27, 2006
tfnaaf's Avatar
BLDNPSI Mod
check your air pressure. There are a lot of idiots that think all tires should have MAX air pressure and could make it handle similar to the way you describe
alaga
25
Aug 13, 2015 04:42 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
