Quick question
Old Oct 19, 2006
K.Low's Avatar
K.Low is an unknown quantity at this point
Quick question
Will 195/65/15 winter tires fit on my civic ???
I have 185/65/15 now...i know its stupid but i need to be sure.
Thanks alot guys.
Old Oct 19, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
yes, but 195/60/15 if you can. thats the OEM size
Old Oct 19, 2006
K.Low's Avatar
Is there gonna be a problem if i run 65 instead of 60 ??
thanks
Old Oct 20, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
thanks
Nope no problems at all, only your speedometer will be off slighty, because 195/65 is slightly bigger than the stock size. You probably won't even notice.
Old Oct 20, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
i have 205/40/17 my speedometers off by a couple numbers compared to the Laser gun
Old Oct 20, 2006
ronaldo9's Avatar
If your dropped it will rub your fender with 195/65/15. I have 185/60/15 and I wanted to go wider but the shop didn't recommend it bc it would rub and I'm dropped about 1.75" on SI's.
Old Oct 20, 2006
K.Low's Avatar
Stock suspension is back on so i dont think it should be a problem thanks.
Thanks alot for the help guys.
Old Oct 20, 2006
CenZ's Avatar
PWIT
are you dropped at all? cause i got 205/65/15 on my stealies for winter wheels before my car was dropped, didnt think it would cause a problem. but now my car is dropped. im tucking the 185/60/15 tires i have on right now, and i cant turn fully with my winter wheels on. it rubs on the side, so becare. i know mine are even bigger than the ones you want but still.
Old Oct 20, 2006
CenZ's Avatar
PWIT
ok, i need to read, the guy before me said the same thing lol.
Old Oct 20, 2006
K.Low's Avatar
No im not dropped anymore.
Old Oct 23, 2006
K.Low's Avatar
edit
Old Oct 25, 2006
04civic07's Avatar
yeah... ummm no 195/60/15 will NOT rub.... not even close, but then again if you are running +35 or less offset, or dropped your car like a hundred inches then it'll rub. but that is OEM stock size tires and i'm talking about the ex alloys.... 15x6.... as for speedometer... really it wont make a difference or at least wont matter. but then again, i assume you are not running ex alloys so if you're running steelies... go for the 65's cuz i think they're 5.5 width, but still shouldnt be rubbing even with lowering springs
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
