Will these rims fit?
Old Mar 14, 2006
daviddittmer's Avatar
daviddittmer is an unknown quantity at this point
Check the specs at the bottom of this page:
http://www.cbwheels.com/gt5.htm
I'm interested in the 17's. I'm not sure how to figure out what rims will fit on a Civic... I have stock 15's right now, on my '05 DX Coupe
Old Mar 14, 2006
blackavian's Avatar
blackavian is an unknown quantity at this point
I believe the first listed bolt pattern is the one that fits our 7th gens. I own a 2001, but doubt that they have changed the pattern. I purchased rims for my car three years back and those are the specs coming to mind. I figured since it is late, you'd want some response tonight. Double check just to be sure. Also, if you go to any tire place that does aftermarket rims they'll be able to tell you for sure.
Old Mar 14, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
just read here and you will find all your answers.
Old Mar 14, 2006
I have read up on the forums to try and learn as much as I can; the thing that I am unsure about is "Offset". Is there one specific offset number that is correct for 7th gens, or can the number vary depending on the size of the rim?
These ones have a listed offset of 42mm.
Old Mar 14, 2006
LiKEaFeRiO's Avatar
The offset can vary depending on various factors such as width and size.
There isn't one specific offset that'll fit 7thgens.
Old Mar 14, 2006
frostyman's Avatar
frostyman is an unknown quantity at this point
look in the tire and wheel faq sticky. The answer is right in the first post, it says how much the offset should be and what range is okay.
Old Mar 14, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Strycker
Aug 18, 2015 02:25 PM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
afinuf12
Jul 28, 2015 04:44 PM
