Brakes starting to fail? idk...
Old Jan 3, 2006
J Smith's Avatar
J Smith is an unknown quantity at this point
I have 60k miles on my car
I have noticed that my brakes are starting to suck
I changed them once...
I only changed the front ones
I guess I have to change them again... But, this time should I change the drums to? how much do those cost?
Im guessing I need rotors and pads again? can I DIY this? or should i go to a mechanic
Old Jan 3, 2006
60k wow i had mine done at 20k new pads and then at 40k now its almost time for more. i would take it to a shop because brakes can be tricky. have them check the rear drums too. but the front is cheap. get a pair of brembo blank rotors from www.dezod.com and then get some oem pads from the dealer. should be a lil over $100. then just have em installed. some places will include the brake check as part of the labor if you decide to have them replace the brakes too.
Old Jan 3, 2006
v8eaterokv6's Avatar
i have a new home do u
**** i got 75,000 on the original pads and still have a quarter of an inch left
Old Jan 3, 2006
blouisgod's Avatar
Life Begins > 6800rpms
im at 55k on originals but it all depends on the type of driving you do and the type of driver you are.
Old Jan 3, 2006
J Smith's Avatar
how much are rear drums? can i get them online?
my car sounds like a bird when i let off the brakes and its coming from the rear =\
Old Jan 3, 2006
SinaloaCivic's Avatar
Ill punch you in the face before you visit Myspace
SinaloaCivic is an unknown quantity at this point
heh im at 17K and i feel my brakes as OK, now doesnt the brake fluid look clear when its new??? lol mines all orange.....
Old Jan 3, 2006
ragingSPAM's Avatar
I just burnt my tongue
my original pads went out at 15k miles...replaced them once with some autozone crap than ran them for another 20k switched to another pair than at 45k which im now at i have brembo cross drilled/slotted rotors along with ceramic/semi metallic pads from PBR
Old Jan 3, 2006
show0and2go's Avatar
show0and2go is an unknown quantity at this point
yeah my fluid is real real low and just nasty.
Old Jan 3, 2006
dont forget the fluid MUST be changed every 3 years regardless of mileage
Old Jan 3, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
There's no indicators in the rear. You need to pull the drum cover off and look at the shoes.
Refer to the sticky thread up top.
Old Jan 3, 2006
I'm getting mine changed 8am tomorow morning. At the moment I basically have no brakes. Its all downshifts.
Old Jan 3, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
If ur brakes vibrate, squeal, or makes long stops = replace pads and even rotors
http://www.autopartswarehouse.com
Get some blanks and hawks Now rep us all
Old Jan 3, 2006
shmik1's Avatar
when i had my fronts done.. about 22k, the rears had to be adjusted because they werent working properly and the fronts warped because of being overworked from the backs not doin their job.
Old Jan 3, 2006
also a common problem is the lug nuts being torqued differently which can warp the rotors too.
Old Jan 3, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Start driving in a city!
P.S. I changed my 1st set of pads @ 45k at the front and the rear.
Old Jan 9, 2006
J Smith's Avatar
where can i order rear brakes?
Old Jan 9, 2006
dealer? there aren't really any performance drums lol
Old Jan 9, 2006
i only drive in the city maybe 20 miles a week are highway. i just down shift a lot
Old Jan 9, 2006
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
all i gotta say is screw all you guys.. i got the brakes done the day after i signed and got all the paper work done on my civic out of safety... ( i bought a car from a guy and he said he had new brakes on it .. so i believed him .. well 3 days later the brakes failed and i tore the tranny out of it stopping... so now every car i buy i put in new brakes the next day or so after FOR MY SAFETY AND EVERYONE ELSES!! )
and now 18k miles later i need pads, rotors, drums, shoes and calipers...
i deliver pizza in mine and the brakes TAKE A BEATING!!
im upgrading to stainless steel lines , hawk pads, brembo drilled/slotted rotors , Genuine auto parts drums and shoes and royal purple brake fluid...
lol my brakes are gonna be KING **** .. but i still gotta fix my civic... so after thats fixed its gonna be BRAKES ... then i should have no worries for about another 30-40k miles..
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
gabrown2
Apr 11, 2015 08:22 PM
black2k1vtec
Dec 6, 2001 09:49 PM
TaiChi
Canada West
Nov 8, 2001 01:21 AM
