plastic rings???
Old Dec 16, 2005
rockrosa's Avatar
Blacked Out Crew
rockrosa is an unknown quantity at this point
plastic rings???
When I bought my new wheels, they came with these black plastic rings (hub centrics??) Do I need to add them when installing my wheels in the spring???
Old Dec 16, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
AKA hubcentrics, yes you should use them.
Old Dec 17, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
plastic? you should get some anodized metal, eventually the plastic will melt.
Old Dec 17, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
plastic is no good, my friend had them and they broke apart after 1 year.
Old Dec 17, 2005
rockrosa's Avatar
Blacked Out Crew
where can i get the metal ones?
Old Dec 17, 2005
Jap-Euro Fusion
Discount tire.
Old Dec 27, 2005
rockrosa's Avatar
Blacked Out Crew
Discount tire.
just bought them from discount tire, only $15. Thanks Boilermaker1!
Old Dec 27, 2005
Jap-Euro Fusion
ONLY???
They used to charge 8.
Those A-holes jacked the price. I know this because I end up replacing those things every now and then because I bang em up pretty good taking the wheels on and off so much. I got stuck buying a set of the 15 ones and was none to happy with them for doubling the price
Old Dec 29, 2005
sil04ver's Avatar
sil04ver is an unknown quantity at this point
Just got my rims in the mail today, I got some too. How do you install them? what do they do?
Old Dec 29, 2005
rockrosa's Avatar
Blacked Out Crew
What did you get for rims?
Old Dec 29, 2005
rockrosa's Avatar
Blacked Out Crew
Remove the center cap on the wheel so you can see through to the hub. If the wheel absolutely fits against the hub with NO gaps, then you dont need them. If you see the tiniest amount of space anywhere, take off the rims, and get rings. Whats happening is that the lugs are holding the wheel in place when all they are supposed to do is hold the wheel against the hub. They help the aftermarket wheel hub fit snuggly, and centered, on the hub.
Old Dec 29, 2005
Jap-Euro Fusion
This can't possibly be a serious question.
In the event it is....
The pink ring in the hub is the hubcentric.
Put it on the hub, put the wheel on.
Old Dec 31, 2005
rockrosa's Avatar
Blacked Out Crew
Should I put on my new wheels myself, or wait to have a shop or the dealer to do it? How much will it cost just to install wheels that are already mounted and balanced?
Old Dec 31, 2005
hdave's Avatar
hdave is an unknown quantity at this point
what purpose do they serve?
i have a hweel with a +45 offset which might cause rubbing, can i use hubcentric or washers so it wont rub anymore?
Old Dec 31, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Hubcentric rings center the wheel more precisely on the hub, it won't do anything to help your rubbing issue.
Old Dec 31, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
lmao someone needs to close this thread before it turns into tire q central.....
Old Dec 31, 2005
hdave's Avatar
sorry for the dumb question but thanks for the answer
Old Dec 31, 2005
shroomster's Avatar
nooooo...i was talking about rockrosa not you hehe...
Old Dec 31, 2005
hdave's Avatar
ohh
and btw regarding that question LOL
rockrosa i suggest doing it yourself, itll take 30min at most with stock jack and wrench.
Old Dec 31, 2005
rockrosa's Avatar
Blacked Out Crew
thanks hdave! I'll give it a try in the spring!
Old Jan 1, 2006
hdave's Avatar
cool. its always great to learn to do things urself.
its exactly like change a flat tire
good luck
Old Jan 1, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
If you need more clearance between the tire/wheel combo and strut, you need a spacer, and if applicable, hubcentric rings. There are hubcentric spacers aswell, but those don't start until 15mm and is not applicable for your application.
Remember that a lower offset will push the wheel further outboard (towards the fender).
Old Jan 1, 2006
hdave's Avatar
can i jsut use four washers from home depot to adjust my offset?
Old Jan 1, 2006
Axxe's Avatar
NO, you do not want to do this. Just buy proper spacers, they are not expensive.
Old Jan 2, 2006
hdave's Avatar
oh cool i didnt know there were spacers for this kinda thing.
thanks a lot.
Old Jan 2, 2006
Axxe's Avatar
No problem. Just promise me to ask questions before putting washers anywhere the don't belong
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
jsmithe2010
Sep 25, 2015 07:42 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Jrosa
Sep 14, 2015 08:24 PM
MichaelLW
Sep 14, 2015 07:15 AM
