16x7 wheel...recommended tire size?
Old Dec 3, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Question 16x7 wheel...recommended tire size?
I need to get some new tires on the Vic. I currently have 205/50 16 tires on 16x7 wheels. Can I step up to a 215/45 16, or is the 7" wheel too narrow? I want to run a wider tire to increase traction / footprint.
Old Dec 4, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Think about how many people are running 215/45/17 tires on a 17x7".
Old Dec 4, 2005
Sarcasim aside, I currently have ES100s which are 205s and the sidewall "hangs over" the wheel a little bit. My concern is whether a 215 will hang over even further. I am sure plenty of people are running this size tire, but that doesn't mean it looks good.
BTW...my plan is to get a set of RT-615s.
Old Dec 4, 2005
slicksivik's Avatar
i had 215/40/16 on my car and they were fine, a bit small tho in sidewall.
Old Dec 4, 2005
I like the look of smaller sidewalls. I don't think a smaller sidewall is an issue unless the sidewall is too soft (and therefore flexes too much).
Old Dec 4, 2005
Jap-Euro Fusion
The only 16 falken makes the 615 in is 205/40. Don't hold your breath for them to release 215/45. They've been pushing back release dates more often than they're actually releasing tires.
A 215 fits a 7" rim. You can't go claiming you want extra traction, then bitch that it looks goofy because it bulges out. Thats a conflict of interest. The ES100 has an odd sidewall thats designed to be straight and has a huge rim protector bead on it. One tire to the next fits significantly different.
Old Dec 4, 2005
umboutwo's Avatar
umboutwo is an unknown quantity at this point
215 45 16 should be fine, I my self am running 225 45 16 es100 and they look fine, they dont even buldge out, but if your car is lowered you might have to roll your fender like i did. i have about 1.75 inch drop in the front and 1.5 in the rear. I will try to post some pic of the side wall.
Old Dec 4, 2005
I thought they were going to release all sizes after the SEMA show last month??? I am not in a huge rush to get the tires--I am going to replace my stupid KWs first.
Old Dec 4, 2005
And you have a 16x7 wheel?
Old Dec 4, 2005
umboutwo's Avatar
Here you go
Old Dec 4, 2005
umboutwo's Avatar
yes i have 16x7
Old Dec 4, 2005
Here you go
I only see red Xs...
Old Dec 6, 2005
umboutwo's Avatar
sorry about that bro, let me try it again
ID:	62653   Click image for larger version
Old Dec 7, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
I have 17x7.5 w/ 225/45/17's and they don't rub ...
Old Dec 7, 2005
vietstylez's Avatar
^^ you must have NO drop at all, cause i rubbed with 215/45/17's
right now got 205/45/16's an lovin it
Old Dec 7, 2005
Sick Cycle's Avatar
I have a 1.5" drop.
what offset are your rims?
Old Dec 7, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
This link will help you dramaticaly.
It has tire size calculator
http://www.carbibles.com/tyre_bible.html
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
