Plug patch combo vs. patch
Old Nov 21, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
ok...My soon-to-be father in law is of the old school thinking that radial tires do not accept plugs properly.
this being said, this past Saturday, he came into my shop and needed 2 tires fixed. The only thing we use in the shop unless we run out, are plug/patch combos....
this is similar to the style we use....inserted from inside of tire through penetration hole and sealed from inside by patch... this pic loks like it is a metal plug which I highly doubt it would be, but just in case, the entire one we use is made of rubber and similar compounds...
with the way todays tires are manufactured, I don't think that he will incur any problems as no one else has incurred any problems (bubbles, belt separations, blowouts caused by plug/patch). I feel as long as it is done properly there will be no complications, save for the tire is not a 'virgin' (read that on another website) anymore, hehe. that said does anyone else have any input as to if there is any grounding to his ideas about plug/patches being bad for radials or not?
thanks in advance, I only ask this cuz I've never really stopped to analyze this at all, what with having done at least 4 or 5 hundred tire repairs at least, using the plug/patches, I even did one on my mom's Rav-4. oh well opinonate away fellow 7th genners....
Old Nov 22, 2005
shroomster's Avatar
Anyone?......Anyone?.......Anyone?........
Old Nov 22, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Do you really need to bump a thread thats 11 hours old? It would have made it 6 posts down the forum. Completely unnecessary
Old Nov 22, 2005
shroomster's Avatar
I'm definitely bookmarking this link...
everything from the stickies is here in one neat little package save for wheel and tire sizes...
yeah I see your point about bumping something like this, I just like things to run quickly I dunno....
Old Nov 22, 2005
shroomster's Avatar
I guess no one else has an opinion on this?
Old Nov 23, 2005
shmik1's Avatar
combos are fine, we've never had ANYONE come back to have a combo re-done.
Old Nov 23, 2005
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
They are fine, seperate plug and patch is better tho.
Old Nov 24, 2005
shroomster's Avatar
if you inadvertantly place the patch wrong you could miss sealing the inner injury.... thus making the repair unsafe....
Old Nov 29, 2005
EMTwannabe's Avatar
Actually you'd have to be pretty blind to miss seeing the plug that would have been put in minutes before. By using a plug/patch combo there is always an air bubble that cannot be pressed out if the puncture went in on an angle. You can easily see the bump in the patch where the plug is twisted. When you use a seperate plug you can grind the plug right down level with the inner liner; leaving a smooth surface to apply your patch.
Old Nov 29, 2005
shroomster's Avatar
it's safer to grind and smooth inside before doing any repair work, even if you're not using a separate plug/patch its safer to grind down inner before repair IMO, and by missing I meant to say not getting it properly centered, er go, placing patch nearly off the plug...or not waiting for cement to dry and having patch slip... when applying a separate plug always level the plug with the inner liner, you in turn negate the possibility of creating more damage by having to grind down the plug on the inside....
Old Nov 29, 2005
EMTwannabe's Avatar
I meant you elimate the posibility of having an air bubble with the one piece plug/patch. When you use a plug/patch combo, you CANNOT grind the plug stem level (since it's one piece). Sometimes an air bubble is inevitable.
Old Nov 29, 2005
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Maybe he should get the road hazrad warranty. I have those on my tires. It was free with the purchase of 4 so why not get it, but if I do encounter any type of tire damage then the tire is replaced with a new one at no cost to me. I figured more people would do this then rather pay for some crappy patch job.
Old Nov 29, 2005
shroomster's Avatar
agreed
I do not know of any place that would w/o a doubt replace the tire w/o properly inspecting it. They will do what they can to avoid replacing a tire, unless need be (sidewall or shoulder damage or interior malfunction barring). If they do that they are losing money. if it can be repaired theywill do it, if they cannot fix it they will most often judge either mileage or in wal-mart's case tread wear to pro-rate a tire. I have certificates from Discount Tire on my tires, they will certificate any tire you bring in as long as its w/in a certain tread (correct me on that if I'm wrong, but they did it for me when i had falken 502's, yes 502 not 512). the tires that were on his truck were original with sale of vehicle, so no warranty is issued with them.
Old Nov 30, 2005
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
He is worried about nuthin man, you did him a good job bro, I have had my same tire on my vic plugged 3 times! A patch and a plug is the best repair you can get for a flat/leaking tire! Costco fixes my leaks/flats and they use patch/plug , to me the best repair for a tire. Why is he worried???????????????
Old Nov 30, 2005
shroomster's Avatar
I'll let you read the first two lines of the first post again
fecrni
Aug 8, 2015 06:15 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
