upgraded to powerslot
You bought a used dog??
i just finished cruzin around to work in my rotors and pads and i dont really feel a difference from stock to powerslot/hawk hps. hopefully it'll feel better once their brocken in. also i was looking at the rotors and noticed the pads looked like they were touching the rotor. is that right or is there supposed to be like .5mm gap or something???
Get some better brake fluid and stainless steel brake lines... It should give you better brake feel! I know I did! And I don't really notice fading when I go auto-x and track!
Originally Posted by def01tones
^^^yeah i do need to bleed the brakes and put new fluid, so ill be doing that pretty soon. how would stainless brake lines improve stopping??
hmm i've heard they are supposed to stop better. Guess not. But as least they won't overheat and warp like stupid stock. Mine feel very shakey when using em more than a few times.
yea i still have a little shake in the steering wheel while braking, but they work fine and feel fine in the pedal, whenever the time comes im'a upgrade my rotors too.
Originally Posted by Blahman240
try slamming on the brakes... you'll notice the stop distance decrease.
Honestly, why anyone bothers wasting money on anything more than blanks is beyond me.
This car doesn't weigh enough and can't go fast enough to overpower the brakes under anything but race track conditions.
Stick a piece of paper between the pad and the rotor.... a piece of paper is between .007 and .010"
There will not be a visible gap, all there is is the pressure being released.
Originally Posted by dariusld
They don't, they help with "feel".
Originally Posted by civic-king
the rubber brake lines expand when pressurized, (pascal's law) stainless steel is more reselent to streaching, since it's made of metal and all...so yes, it does improve braking. plus, SS does not rot, tear, or ware out as much as rubber....
you are less likely to die in a firey crash.
what do you mean, brake test? it would not decrease stopping distance, if that is what you're asking, but it would just resist corrosion more, and take less effort to produce maximum pressure on caliper pistons. i consider that to be an improvment.
AffliictiioN
Sep 16, 2015 02:21 PM
KikAzz
Sep 4, 2015 12:36 PM
