Any damage from thumb tack in tire?
Old Jul 3, 2005
nyyanks81's Avatar
nyyanks81 will become famous soon enoughnyyanks81 will become famous soon enough
I was checking out my tires today and found a thumb tack in the tread (in one of the grooves) which I pulled out.
Can this thumb tack cause any damage to the tire (leaks)?
The nail piece and the plastic part of the thumb tack were both intact when I pulled it out.
Old Jul 3, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
If it got caught in the block you probably have enough rubber to not worry about it. If it got in the grooves, you might want to think about worrying. I'd monitor the tire for the next few days, see if the pressure drops. If it does, take it and get it leak tested and patched at the tire shop.
Old Jul 3, 2005
nyyanks81's Avatar
How thick are the stock tires anyway (from the groove to the point where the puncture is deep enough to let air out)?
Old Jul 7, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
If it did't hiss when you removed it, you're probably ok. You could put a soapy water solution on the tire and see if any bubbles start forming. Just keep an eye on it.
Old Jul 7, 2005
civic01vtec's Avatar
well, this happened 3 days ago......any updates ???
Old Jul 9, 2005
nyyanks81's Avatar
It looks ok so far. I drove it on the expressway the other day for like 120 miles and it hasn't gone flat.
srtlat
Jul 17, 2015 11:53 PM
SpecialRequest
Jul 7, 2015 07:52 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
