19" rims and suspension
Old Jun 20, 2005
LC's Avatar
LC
LC is an unknown quantity at this point
I got 19's on my civic coupe and I was wondering if I can get it dropped without rubbing against the body. Im looking into getting the H&R, 1.3 drop, what do you guys think?
Old Jun 21, 2005
chrisleecool's Avatar
i'm dropped on h&r's with 215/40/18 and I rubbed in the rear and a bit in the front (wide turn) , but I solved the problem by roller the rear fender inside. But i still rub a little bit when hitting big bumps on highway (with 3~4people in)
there's no gap in the rear maybe 1finger gap at most
about 1.5finger gap in the front(passenger) less than a finger gap(driver)
I'd say go with Eibach Prokit instead of H&R's
Old Oct 17, 2005
LC's Avatar
LC
can i get more input from people that have 19's
Old Oct 18, 2005
XTREME2K2CIVIC's Avatar
Reppin Stage 7
I've had 3 sets of 19's and only have trouble when I completely lock the front wheels. I'm dropped to the max on my B&G Coilovers... Gonna have to remove the front plastic inner fender to ride as low as I am but damn does it look good... And in the rear I'm runnin a little negative camber so I dont have to worry about rubbing.. But as long as you balance and rotate regularly its cool... LMK if you need anymore info man.. Oh and I've run 215/35/19" tires... I've run Falken Azenis St-115's and now am running the same size but in Nitto Neo Gens which are supposed to be good for running with negative camber and so far are running great....
Old Oct 18, 2005
brazilian7th's Avatar
brazilian7th is an unknown quantity at this point
I'm riding on 19x8 et43 on parada spec2 215/35R19
Had to work all inner fender to go low as it is. On front, plastic was cutted in some places
Sometimes rub on front bumper but no big deal
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
