Tire on 45 Offset 16" Wheel.
Old Apr 14, 2005
Vantage's Avatar
Vantage should not be trusted
Hey people's, i just bought my intermilano rg6's and need to find tires to throw on them. I want to know if 215/40's will fit, even with the 45 offset, or if i should just stick to 205/40's. Id rather get the 215's but i dont want ANY rubbing.
Old Apr 15, 2005
Vantage's Avatar
someone give me their imput, i get the rims tnight and i wanna buy tires in the next 2 weeks. 215/40/16's or 205/40/16's ???
Old Apr 15, 2005
Roo's Avatar
Roo
Roo is an unknown quantity at this point
Won't 205/40/16's result in a fairly big speedometer error? 205/50/16's should be much closer to stock.
Lots of owners of 16 run with 205/45/16's -- which has ~3% speedo error. In my opinion if you wanted to run lower profile tires, why not just get 17" rims to start with? (avoid the speedo error)
45mm offset is close to the max according to the rule of thumb - however it "might" fit ok, or it might not. Offset is not the only factor.
I suggest that you buy your tires from a reputable tire shop that will "do the right thing" and help you get tires that don't rub.
Roo
Old Apr 15, 2005
Vantage's Avatar
i thought 40's were the closest to matching stock, Id like to keep speedo normal, so ill look for 205/45's or 205/50's thanks. I was thinking 45 was fine offset. But the guy who's selling them to me had them on a EK hatch, lowered 2.5" and he had no problems, so i figured i should be ok, since 7th gen's have more fender clearance, and im only lowered 1.3"
There are some 205/55/16's for sale on a local buysell, u think the sidewall is to big? they are dirt cheap. 200 bucks canadian for 4, with 60% tread. Think this will look fine or ??
Old Apr 18, 2005
Roo's Avatar
Roo
Look at the bottom of this page - Click on the tire calculator link. Plug in your numbers, and you'll see which sizes match stock.
Old Apr 18, 2005
Vantage's Avatar
not to worried about that now, gunna buy 215/45's cause the idiot i bought the rims off of, said they were 45. I get them home and check, and they are actually+38
SidCivic
Oct 3, 2015 06:00 AM
Strycker
Aug 18, 2015 02:25 PM
alaga
25
Aug 13, 2015 04:42 PM
Misfit2613
Jul 30, 2015 09:49 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
