35 Offset
Old Mar 28, 2005
InOvAtStyL's Avatar
Never Too Wide, Never Too Extreme
InOvAtStyL is on a distinguished road
35 Offset
Can I fit 35 offset in the rears? I'm not sure cause I don't have the car on me for a while and I won't be able to try it on for testing. I wanna get tires, but it'd be pointless to waste money on tires if the rims don't even fit. I've tried to search, but all I see are 38 offesets. I don't see any mention of 35. Would I need a spacer? Any info would be appreciated. Thanks
Old Mar 28, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You don't need a spacer. they're already way out as it is. How big is the wheel and how big is the tire you want to put on it? I put a 215/45/17 on a +37 rim and have no problems.
Old Mar 28, 2005
InOvAtStyL's Avatar
well the rim is 9.5" wide and I'm still shopping for some tires. I just need to know if it'll fit without hitting the arm.
Old Mar 28, 2005
olytrojan's Avatar
Senior Member
olytrojan is an unknown quantity at this point
holys*** 9.5 you're , with that wide of a wheel you might have a problem. when i go to work tomorrow i'll call our wheel dept. and check on that for you.
Old Mar 28, 2005
InOvAtStyL's Avatar
thanks. I need these wheels cause my 8" wide rims before for my widebody wasn't wide enough. Now that the wide body is going to get pulled out even more to a 6" overall widebody. I def. needed bigger rims. And it just so happened that a company offered to sponsor me with these rims. So now my only prob. is to make them fit.
Old Mar 28, 2005
Jap-Euro Fusion
I don't know what offset you're running right now, but figure with an 9.5'" wheel, you're going about another 1/2-3/4" further in from where you are right now, and about 3/4-1" further out than you are right now. So.... figure out where the inside of the rim is now, go in about 1" and see how much room you got. I doubt very much, and make sure you check on the left side that you dont run into any of the fuel system filler stuff.
Old Mar 29, 2005
InOvAtStyL's Avatar
Thanks for the tip. I'll be sure to do some rough estimates on fittings and check for the left side. Thanks for the advice.
Old Mar 29, 2005
Nodnero's Avatar
6"?!?!!? Dayum that thing is going to need its own zipcode!!! Supra-width for cryin out loud!
Old Mar 29, 2005
InOvAtStyL's Avatar
well. it's 6" overall. So basically 3" on each side. I didn't think it was that wide. I was actually thinking of going 4" on each side. Still have time to think about it cause I have about another week till they start fabricating the rear 1/2 of the car.
Old Mar 29, 2005
blackbullet's Avatar
The Legend
Lucky!!! lol Can't wait to see them.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
Strycker
Aug 18, 2015 02:25 PM
