Hub removal?
Old Dec 14, 2004
someguy's Avatar
someguy is an unknown quantity at this point
Hub removal?
Ok, here is my problem. I broke two of the studs off on my front wheel. I dont have a hub puller and neither does Autozone. Is there any other way I can pull the hub off? anything would be helpful.
Old Dec 14, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
hub as in hubcaps?
if so.. you have to take the lugs off.. or use a hammer to smash it off..
Old Dec 14, 2004
someguy's Avatar
no wheel hub...holding the the wheel studs.
Old Dec 14, 2004
againifall's Avatar
Go Team Venture!
o... i have no idea..
Old Dec 15, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The tools required to push the hub apart are a press and some specialized tools for Hondas.
It would be most likely be too expensive to buy these items for one job.
Take the entire front assembly off. Knuckle and hub. Take it to any automotive machine shop. Take them the lug nuts, since they will most likely not have them. They should charge you 40 bucks to press the new lugs in.
If you really have a hard time with it, go to a big tire repair place, they should be able to do it.
For me, I am a Honda mech, and it just cost too much now for the press and tools, but one day I will. When this happens to me, I take them to a friends machine shop.
Old Dec 15, 2004
someguy's Avatar
thanks man. do you think they would be able to get the old broken ones out too?
Sep 26, 2023 06:44 PM
GotSiR
Jun 23, 2016 04:06 PM
EdGasket
40
Nov 27, 2015 11:11 AM
muttleytm
Jul 11, 2015 06:00 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
