Quick offset question!
Old Dec 1, 2004
Blkcivic's Avatar
Wht is a good offset for 17" wheels? around +43 range? i had 17's b4 but sold them, never knew wht offset they were cuz it was used...now i'm gettin new ones so i need to know. and if i get +40 will it make it stick out more or in more?
Old Dec 1, 2004
sigtrap's Avatar
sigtrap is an unknown quantity at this point
+40 sticks out more (99% sure of this)
i have +42, i think that is typical for 17's
Old Dec 4, 2004
Mr.EL's Avatar
Mr.EL is an unknown quantity at this point
I just posted a similar question. I have 17's with a 40 offset, and they are flush with the fender. I'm wondering if they are too far out to lower the car now.
Old Dec 4, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
I have 42mm on 7.5, they sit flush with the end of the fender.
Old Dec 5, 2004
Blkcivic's Avatar
so +40 is a bad offset for slammin the car?
Old Dec 5, 2004
sigtrap's Avatar
more likely to hit the fender with a 40 over a 42 or higher
i HAD 17 inch wheels with a 40 offset with no problems, but was only dropped 1.3 on h&r springs. Now i have a 42 offset.
Old Dec 5, 2004
slickdip's Avatar
slickdip is an unknown quantity at this point
wut about a 35 offset???
i have 18's with 35 offset, still have to put them on, thinking about dropping it about 1.5-1.8 inch.
Old Dec 6, 2004
flotsamm's Avatar
The more plus offset means theyre not as wide. So a 30mm offset will make the wheels stick out further then a 40mm offset.
Old Dec 6, 2004
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
I heard about this offset... what the hell is it for and why do we need it? I lowered my car about 2.5 inches and want 17's. Will I need this?
Old Dec 6, 2004
flotsamm's Avatar
Choosing a good offset is important whe lowering or getting larger wheels. For example, say if you lowered your car 2" and you have 17" wheels that have a +30mm offset. The +30mm is going to make the wheel stick out further. Now when you go to choose tires, you'll have to compensate for the wider wheel and get a skinnier tire or you'll rub when the tire tucks into the fender. A good rule of thumb for our cars is to look for a wheel that has 37mm or more postive offset.
http://www.discounttire.com/dtc/broc...eelOffsets.jsp
Old Dec 6, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
offset is dependent on width..
your fine w/ a +40 17x7 or 17x7.5 dont worry
lower=stick out further
higher= stick in further
remember the diff between +43 and +40 is 3mm so worst case scenario camber her in
on my car Es1 sedan i can do as much as +26 on a 7.5 in my rear but i have alot of fender mods.
Old Dec 6, 2004
low04's Avatar
low04 is an unknown quantity at this point
most 17's are around 38-43 range and all should work ok on a drop
Old Dec 6, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Hello crazy torquesteer.
And I wouldn't do it... Ms. Tire will get very friendly with Mr. Fender Lip.
Old Dec 6, 2004
low04's Avatar
most 17's are made in a range from 38-44 for the most part. i havent seen many problems in getting them to work if you get an offset that will stick out a little further then you can always roll the fenders
Old Dec 6, 2004
Blkcivic's Avatar
thanx for all the replys.... actually i'm getting GL57c 17.5 +40 offset, so i guess tire size also makes a difference too. I was worrying about +40 sticking out hitting the out side fender when i drop it more cuz i want the front to be close to tucking
Old Dec 9, 2004
so I need to get an offset when getting rims??? 17s and 2.5 drop
Old Dec 9, 2004
Wolfgang5884's Avatar
I have 17s with an offset of 42 and everything is fine
rman1900
21
Sep 10, 2018 04:52 PM
Strycker
Aug 2, 2015 08:40 PM
Misfit2613
Jul 30, 2015 09:49 AM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
