braking feels like shiet now..
Old Oct 27, 2004
jttegx's Avatar
OMNES AD UNUM
before i start heres my wheel/suspension set up and car info:
2003 Civic EX Coupe Automatic, 16k miles;
-skunk2 coilovers
-spc rear camber kit
-215/45/17 rims are 45mm offset (rota subzero) wrapped w/wanli s-1099 tires (aka yokohama avs sport knockoffs) 70% thread left on these tires
so anything related with brakes/rotors are completely oem/stock
since it rained, the next following days/week, when i brake during normal driving conditions, the braking performance is pretty horrible compared to the days it werent raining. i have a feeling it may be my brake pads prob because i wore them out quickly? (i did do a few launchs while holding the brake and gas pedal the same time). so i wanted to ask anyone here that have an educated guess on what may be the problem with my braking performance? compared to the past and now, it feels like my brake pads were slit in half
Old Oct 27, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Is this in the rain? Or after the rain when its dry again.
If its in the rain, its because your tires are ****.
If its after the rain, you need to describe a little more what's going on.
Old Oct 27, 2004
jttegx's Avatar
OMNES AD UNUM
after rain.
heres an example: im driving 30mph on smooth surface street (100% dry/sunny). when im stepping on the brake pedal like half way down, the brake pedal feels like its vibrating as i am braking to a stop. it 'feels' like their is a small rock stuck in between the caliper and brake pad when i hit the brakes. its completely fine when the car is accelerating and in motion without the brakes stepped on. i checked the rotors, no sign of any damage.
Old Oct 28, 2004
dru106's Avatar
ThE CoRRupToR
warped rotor can cause that and u cant really tell if u just look at it
Old Oct 31, 2004
trance4mer's Avatar
trance4mer is an unknown quantity at this point
thats the same sh*t i have!! i make a new thread before reading this complainin about the same thing. so it could be the rotor huh??? yeah it feels like there is a little rock between the caliper and the rotor
Old Oct 31, 2004
woodee's Avatar
woodee will become famous soon enough
I had the same problem. I'm with Dru. Swapped out rotors for some Brembo replacements (non-slotted, non-crossdrilled). only costs $28.00 each. Problem solved.
conspiracy90
Jun 7, 2023 01:01 PM
sbi
20
Oct 23, 2015 01:34 PM
cukaracha
Jun 4, 2015 08:25 AM
bsmiley
Apr 27, 2015 01:27 PM
CapYoda
Jan 7, 2002 03:20 PM
