Need help replacing wheel stud.
Old Oct 15, 2004
Overboost's Avatar
Overboost is an unknown quantity at this point
Post Need help replacing wheel stud.
Did a search and only found info on replacing the back wheel studs but I need to replace 2 studs in the front. My dad and I attempted to remove them a week ago but to no avail. He works mainly on domestics and was trying to knock the hub off. Does anyone have any ideas on how to get the hub off so we can replace the front stud?
Old Oct 15, 2004
tfnaaf's Avatar
BLDNPSI Mod
Ive never changed one on a 7th gen but on pretty much every other honda. You shouldnt ahve to remove the hub to install the studs. If your lucky pound out the new one and usually you can slip teh new stud in and use a lug nut and some washers to pull the stud into the hub.
here is a picture of how to change one on a hummer, but you get the idea.........
a. Removal
1. Rotate spindle (3) to allow clearance for removal of stud (4) from spindle (3).
2. Drive stud (4) from spindle (3). Discard stud (4). b.
Assembly
1. Align splines on stud (4) with splines in spindle (3) and install stud (4) in spindle (3).
2. Install three flat washers (2) and hex nut (1) on stud (4).
3. Tighten hex nut (1) until head on stud (4) seats against spindle (3).
4. Remove and discard hex nut (1) and three flat washers (2).
Old Oct 15, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
a 60 thousand dollar suv isnt our civic i hope you dont use hummer how to's for all your modding
Old Oct 15, 2004
tfnaaf's Avatar
BLDNPSI Mod
was the only picture i could find
Old Oct 15, 2004
dazdncnfusd's Avatar
dazdncnfusd is an unknown quantity at this point
I had to replace the hubs on mine and they needed to be pressed out, I think you can get them out if you have a hub puller (at least that's what I was told) otherwise a shop needs to do it.
Old Oct 15, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
its not hard.. take the front apart and think about it logically.. im guessing u remove the damn reverse driven screw on the rotor.. and then pry the rotor off (it'l stick cause of oxidation (rust) and then hit it out and pull a ew one thru.. use the ^^^^^washer method to properly seat it.
riley
Old Oct 15, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
take the entire spindle off of the car. You will have to remove the ball joints. take off the spindle nut and remove it off of the driveshaft. Then you have to press out the hub from the bearing, then press out the lug bolts, then press some new ones in, then press the hub back on.
I could send you the whole process if you send me your email address
supra8311
Sep 16, 2015 02:07 PM
anddrrey
May 11, 2015 02:30 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
