45mm offset
Old Oct 16, 2004
ROCKET JOCKEY's Avatar
ROCKET JOCKEY has a little shameless behaviour in the past
45mm offset
I am going to purchase some 17 X 7 inch wheels with a 45mm offset . I also have B@G coilovers and I am concerned about rubbing , I am I being paranoid or should I expect some rubbing ? Also will the 45mm offset cause some problems with using a chamber kit ?
Old Oct 16, 2004
Mr.Modify's Avatar
you should be fine with a 45mm offset.....it's camber kit to ;( and no.
Old Oct 16, 2004
danscreations's Avatar
Tuckin' 19's
danscreations is an unknown quantity at this point
You will be fine.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
Strycker
Aug 18, 2015 02:25 PM
