polishing bare metal
ThE FaMiLy SeDaN
inside my wheels is bare aluminum... its rough too
what could i use to buff it down to a flat surface and polish it up..
the grooves r like 1/132nd deep so its really small grooves... i just dont know what to use like as in tooling and polishing compunds
riley
ThE FaMiLy SeDaN
mothers isnt an abrasive so it doesnt do **** besides shine it, no clear coat on the rear section....
i need an abrasive plus polish.. idk the CR's i have have a full polish inside.. these dont.. idk :-/
You'll have to start with sandpaper and work your way from a rougher to finer grit. Then you would do the same thing with the polishing compound.
Personally, I would see if there is a place that can clearcoat it.
ThE FaMiLy SeDaN
why is clearcoated needed its 100% aluminum and cant/wont rust....has no iron in it.. anywho.. idk. seems like alot of work^^^ especially since my valve stem is located in the middle of the wheel and the wheel couldnt get polished around the valve stem.. maybe i'll just powdercoat the back black...:-/
I'm sure they're coated with something. Honda's factory machine finished wheels have the same type of finish inside the rim, and they're clearcoated. I would just leave it alone... there's probably some kind of protectant on it, well for $450 a rim, there better be something on it.
Bruce2
Sep 27, 2015 08:45 PM
Sep 27, 2015 11:33 AM
Bikergofast
Sep 12, 2015 01:36 PM
