Question about bearings?
Recently, everytime I am on the freeway going about 50 or more, my steering wheel shakes. It isnt bad, but very bothering. Then when I put the brakes on from that speed, the steering wheel shakes pretty good and the feel in the brake pad sorda thumps. I am thinking this all has to do with my wheel bearings? What do you all think. I know it isnt my rotors because I have new brembo blanks, I am going to get the tires balanced tomorrow, and see if that helps.
if you have samll bends (from potholes) in your rims that wil do it, even if you get the tire ballanced. my car does the same thing and i just got powerslot slotted and ebc green stuff, its my rims doing it for me. if you take off the tire you should be able to hear the bearings grinding when u turn it or have side to side play.
sounds like 2 different problems...most common causes are as follows
Steering wheel shake = Front wheels out of balance, not nessarily caused by bent wheels
Shake when brake is applied = Front brake rotors need machined, if not replaced
Other things can cause these things to happen but these two things are prolly 99% of the solutions
Originally posted by bobbyd
Yeah, I have seen pretty big bent wheels with no leaks. I would check the alignment and the wheel balance.
Re: Question about bearings?
new doesnt mean that there will be enough material to safely machine them. But that would be a good start. Sometimes a bent hub, or sticking caliper can contribute to the problem
OptimisticWay
46
Oct 15, 2015 02:16 PM
civic98?
Aug 13, 2015 01:32 AM
denierlexiese
Aug 5, 2015 08:58 PM
NoobyKid
Jul 13, 2015 07:53 AM
