Tire Pressure
Old Feb 12, 2004
PJG's Avatar
PJG
PJG is an unknown quantity at this point
Tire Pressure
I normally set my stock tires at 30psi. I just went to the shop, and they told me that with modern cars, they usually set the tire pressure at 40psi.
This could be the solution to my somewhat low gas mileage average of 26mpg.
Thought that you guys should know this, so you could adjust your tire pressure accordingly.
Old Feb 12, 2004
michael_on_18s's Avatar
michael_on_18s is an unknown quantity at this point
i run mine at 35 psi. no problems here
Old Feb 12, 2004
Zzyzx's Avatar
Autocross Junky
Tire pressure is determined by veichle weight. so Psi Varies from car to car.
On the drivers side Door frame, there will be a sticker that tells you what Psi to run the tires at, based on the cars weight. I believe its 30 Front and 30 Rear for our civics. bump 1 to 2 psi per wheel sized increase. (for 17s run 32-34)
Old Feb 12, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
^^ agreed.
over inflating will NOT increase your gas mileage. "Overinflated tires can make your car ride more harshly, are more prone to damage from road hazards, and wear unevenly." pg. 241 on the manual.
Improper inflated tires can cause a crash.
Old Feb 12, 2004
Zzyzx's Avatar
Autocross Junky
I love the tire rack....
Hers a few articles to help explain it a bit more
Air Pressure
Air Pressure Vs Dry performance
air pressure Vs Wet performance
Air pressure for Compititon (this is for Autocross and track days, not drag racing)
Old Feb 12, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
^--- ANOTHER NICE FIND zzYX!
Old Feb 12, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Re: Tire Pressure
--> Moving this to Tire/Wheels forum ...
40 psi sounds too high ... you're gonna wear out the middle of your tires real fast at this pressure. Not to mention having a super harsh ride and probably less control of your car.
Old Feb 12, 2004
robbclark1's Avatar
Retired suspension supermod.
tirerack rocks! Except they don't carry falkens
Old Feb 12, 2004
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Actually putting the stock firestones up to 40psi, is good times, they turn in very nicely, and don't roll over, when they're down at 30, they suck, I drove mine at about 36-37F/32R, and they had mostly uniform treadwear, though they wore out in 20k miles cause of hard driving.
Old Feb 14, 2004
Samari's Avatar
well with low pros you need to set at least 40 right?
Old Feb 14, 2004
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
Not necessarily.. Depends how low..
Old Feb 15, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
19" 215/35 runflat=??? i run 34 front and 33 rear on my sedan is that enuff?
Old Feb 15, 2004
usafstud's Avatar
will, its a matter of preference
i canyon run and road race with my azenis(205/50/15) at 38 psi(hot)
i road raced my civic with stock firestones before at they seem to
work best at 34 psi(hot)
Old Feb 15, 2004
Renamazazo's Avatar
I ran 40 cold for a while... those were fun, they were very responsive
Old Feb 16, 2004
PJG's Avatar
PJG
After driving my car,
The ride was pretty good, and gas mileage slightly increased, so I just left the tire pressure at 40psi.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
cukaracha
Jul 23, 2015 08:50 AM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
