quick question
Old Jan 2, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
quick question
How do i know if a tire fits my rim? Its a dumb question but I really have no idea.
Old Jan 2, 2004
666's Avatar
666
666 is an unknown quantity at this point
Well, what size rim do you have?
For an example, say you have a 17X7" wheel, and a 215/45-17 tire. The first number (the 215) is your tread width in millimeters and the second number (the 45) is the sidewall height. It is the percentage of the tread width 45% of 215 mm will give you the height. The last number is the rim size that the tire fits on, in this case 17".
I should point out that any 17" tire will fit on any 17" wheel, but you have to make sure you get the proper size (width and sidewall) in order to keep your speedometer reading accurate and everything in order.
So if you want to tell us your rim size we can help you find a tire that fits for you.
Old Jan 2, 2004
Vinnie's Avatar
thx for the reply, i have 17 inch motegi mr7s, i was thinkin about getting 215/45/17 falken 512's. will that work>?
Old Jan 2, 2004
666's Avatar
666
Yes those will work as long as your drop is not really low. If it is when you adjust the rear camber it may cause the tire to rub on the fender. If you are worried about this you can get a 205/45-17 and that will have a less chance of rubbing on you and still have the sidewall you want.
Tedverseti
Apr 23, 2020 01:45 PM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
